Activity Forums Apple Final Cut Pro Legacy FCP with AJ-SD93
  • FCP with AJ-SD93
    Posted by Tore Jonssen on January 26, 2006 at 3:02 pm
    Having finished a DVCPro50 PAL project in FCP, I am experiering difficulties mastering my sequence to a Panasonic AJ-SD93. Both print to tape and edit to tape gives me all sorts of problems – jumping time code, picture and audio suddenly showing / not showing etc. Anyone running this combo with success (playback/digitizing material to FCP works fine, it’s the other way around that gives me problems)?
    Tore Jonssen replied 20 years, 7 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    January 26, 2006 at 4:12 pm
    The SD 93 is not an edit deck. If you are trying to master to rs-422/SDI or component it won’t work. YOu can do it through firewire and get the weird, not exactly frame accurate record, but you will not be able to get a frame accurate master out to that deck. You can do it print to video and hit play/record manually, but then your timecode is all willy nilly. You need the sd-930 studio VTR to make proper frame acc. masters. The SD93 works just like the aj-1200A in DVCProHD.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Tore Jonssen
    January 26, 2006 at 7:18 pm
    Thanks a lot Jeremy, that clarified things for me:-)
  • Donald Thompson
    January 26, 2006 at 7:51 pm
    We have experienced similar problems when editing to tape via the firewire interface. Starting programs at 1:00:00:00 requires an 8 frame offset on our deck. In addition there are times when the editor and the tape machine do not communicate correctly. We have to set the editor for dv25 output, edit to tape, change the settings back to DV50 and then output the program.
    There are times when we use the same work around when capturing video from DV25 and DV 50 tapes.
  • Tore Jonssen
    January 27, 2006 at 7:44 am
    Donald, that I didn’t understand…are you using the same deck as me…?
    Also, you say:
    “We have to set the editor for dv25 output, edit to tape,
    change the settings back to DV50 and then output the program.”
    What do you mean excactly?
    I also have a DSR-1500P player/recorder and I am aware of the troubles with outputting excact timecode from FCP through firewire. That only requires a simple workaround though.
    Tore
