Activity › Forums › Apple Final Cut Pro Legacy › FCP will not start up!! Help!!
Posted by Dpmarc on September 15, 2006 at 10:22 amHi fcpHD will not open up, I hit the button in the dock, it bounces and nothing happens. any help is appreciated
MarcMark Landman replied 20 years ago 3 Members · 2 Replies -
Kevin Monahan
September 15, 2006 at 4:45 pmTrash Prefs. If that doesn’t work, Reinstall Studio.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Mark Landman
September 15, 2006 at 9:37 pmIf you feel comfortable messing around in the terminal you could try running the file system check routine from UNIX.
Restart your computer. As soon as you press restart you need to press and hold apple+S (the apple key and the s key). You’ll see the grey startup screen for a moment, then you’ll see white text on a black screen. This is the UNIX shell. At the prompt type
fsck -y
press return
When I have the bouncing icon problem I’ve noticed that fsck usually reports that it’s found a few orphaned threads. When fsck has finished running it will probably state something to the effect that the file system has been changed. If that’s the case, run fsck -y again. Keep running it until the routine reports that the file system appears to be okay. To get back to OSX type
reboot
and press the return key.
A few weeks ago I had the same problem you mentioned, only none of my applications would start. The icons bounced for a minute or two then nothing.
I couldn’t start Tech Tool or any other repair utilities. Running fsck from UNIX was the only thing that saved my bacon.
