Activity Forums Apple Final Cut Pro Legacy FCP vs. DSR-1500a
  • FCP vs. DSR-1500a
    Posted by Tim Vause on November 27, 2009 at 8:07 am
    I cannot get FCP to control a DSR-1500a. I have it hooked up via firewire and also have an external television hooked up for reference. I can see the timeline on the reference monitor but cannot not see anything in the preview window nor can I control the deck through FCP when I go to log and capture. It started out that I could see a tape in the preview window when I went to log and capture but I couldn’t control the deck or capture a clip unless I used capture now.More than one person uses this comp and well long story short I trashed the prefs and now here we are. Am I just missing some setting somewheres.! Anybody care to help? Thanks in advance!
    Tim Vause replied 16 years, 9 months ago 4 Members · 4 Replies
  • Petteri Evilampi
    November 27, 2009 at 9:03 am
    You have to set from dsr-1500 that it is controlled via firewire and set it to remote control mode. Then you open Log and Capture window in FCP and select there a tab “Capture Settings”. You choose Device Control – Firewire ntsc and then Capture / Input – DV NTSC 48 khz. Should work now!
  • Rafael Amador
    November 27, 2009 at 9:04 am
    Hi Tim,
    if you get the picture, the FW connexion is OK.
    You had set “Control Device FW” don’t you?
    rafael
    http://www.nagavideo.com
  • Gary Askham
    November 27, 2009 at 9:58 am
    Have you got the deck’s iLink setting turned on (one of the buttons on the front). Also in the DSR-1500’s menu there is an option to switch control from Firewire to 9-pin remote (it is under the Interface menu item).
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
  • Tim Vause
    November 27, 2009 at 9:20 pm
    thanks guys! Turns out I had the connection on the front of the deck on but it was on 9-pin in the internal menu. Switched it to iLink an’ presto! thanks for the responses, cow comes through for me again!!
