Activity Forums Apple Final Cut Pro Legacy FCP Viewer Window Lagging
  • FCP Viewer Window Lagging
    Posted by Ellis Berman on March 9, 2011 at 12:55 am
    Hello everyone,
    I’m running FCP 7.0.3 on Mac OSX 10.5.8, Processor: 2.16 GHz Intel Core 2 Duo.
    I’m working with NTSC DV 720×480 footage and I’m having trouble with the viewer.
    Whenever I play a clip in the viewer, it starts to lag. When I drag the clip into the timeline, it plays perfectly fine.
    What is going on with the viewer?
    Ellis
    Richard Lord replied 13 years, 8 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    March 9, 2011 at 2:28 pm
    Not sure what’s causeing this, but if you’ll post more info, I’ll bet we can figure it out…
    Lagging, I presume, means it’s dropping frames?
    Post what you’re using as a scratch disk for starters. Might just be the problem.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Ellis Berman
    March 9, 2011 at 5:56 pm
    I’m using my iMac’s built in hard drive.
  • Richard Lord
    January 14, 2013 at 4:42 am
    Did you ever find a solution to this? When I place prores422 clips into the viewer window I get playback issues. It’s only on the time that I get reasonable playback – but I certainly can’t play much back in the viewer.
    1080i prores422 format
    Machine – 2.8 quad-core intel xeon, 12gb ram.
    I’ve never had this issue before on any other mac pro.
    -Rich
