Activity Forums Apple Final Cut Pro Legacy FCP Video Transparency
  • FCP Video Transparency
    Posted by Boris Riabov on January 31, 2014 at 5:08 am
    How to take a form and change the color to transparent.
    For example, a red triangle over a black background.
    copy and reduce the size of the shape and paste it inside of the larger original and then turn this smaller triangle transparent so the result is a red outline of a triangle on a black background inside and out.
    Mark Suszko replied 12 years, 7 months ago 2 Members · 1 Reply
  • Mark Suszko
    February 3, 2014 at 3:00 pm
    Try using the luma or chromakey effect in FCP but also, if you’re just putting a smaller version of one inside the other, try changing the blending (composite) mode, then scaling it down.
