Activity › Forums › Apple Final Cut Pro Legacy › FCP video dropouts
  • FCP video dropouts
    Posted by Gjordan82 on September 28, 2006 at 7:20 pm
    I’m wondering if anyone can tell me what’s the best way to remove video hits (betacam mostly) from clips digitized into fcp v. 5.1.2
    I found the “repair tools” plugin from chv at apples website, but is it effective and does it have and bugs or tweaks?
    Ed Dooley replied 20 years ago 4 Members · 4 Replies
  • Ed Dooley
    September 28, 2006 at 8:56 pm
    If I don’t have many of them, I do it by removing the offending frame and replacing it with the
    previous or next frame. Looks good. If there’s a lot I, well…. I do the same thing.
    Ed
  • David Roth weiss
    September 28, 2006 at 11:37 pm
    [Ed] “I do it by removing the offending frame and replacing it with the
    previous or next frame.”
    Yikes, that’s a scary thought Ed. You mustn’t have much movement in your movies. May I suggest that you don’t do this when moving to HD, when you see that duplicated frame at six times the resolution you’re presently viewing at it may shock you.
    Cloning part of a frame from the next or previous frame is the way this is normally done, and there’s a huge difference. The simple way to do this right in FCP is to duplicate a few frames of your bad video and place that on the video track directly below. Now, slide that one frame ahead, or one frame back depending on the best good frame. Now place an oval shaped mask on the top layer and move and size it until it covers your dropout and shows through the top layer revealing the same section of the frame from the good video below without the dropout. Then, place a softedge on the mask and adjust until you’re happy. There are plugins available that do this more easily, and this is certainly quite easiliy accomplished in both AE and Combustion, but its right there in FCP too.
    DRW
  • Martin Baker
    September 29, 2006 at 2:27 pm
    Our DH_Dropout filter will do what you want:
    https://www.digital-heaven.co.uk/fcplugins/dh_dropout.php
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! DH_RetroTV and DH_Dream plug-ins for FCP
    NEW! Hot Tips video podcast for FCP
  • Ed Dooley
    September 29, 2006 at 6:03 pm
    Scary thought? LOL! I just finished a one-hour documentary shot on Beta, with a half-dozen 1-frame drop outs that I removed
    exactly as I described, and I challenge anyone to pick them out. At least one of them was on a frame during a push, and it’s
    completely invisible. I’m not saying that it’s any substitute for a good filter, but it’s many times faster (and did I say virtually
    invisible) than the method you suggest. Pulling one frame out and replacing with the adjacent frame, and it only lasting 1/30th
    of a second, is consistent with Max Wertheimer’s Experimental Studies on the Study of Motion (and all that Beta Movement and Pi
    Phenomenon mumbo jumbo). 🙂
    Your approach saves more of the undamaged part of the frame, but why spend all that time for a result that doesn’t appear any better to a viewer.
    In other words, *not* a huge difference!
    So, replace a whole frame, a part of a frame, or let a filter do it for you. Easy to do it my way to see if it works for you, easy, but
    much more time-consuming to do it David’s way and compare, and probably easiest to buy a filter.
    Ed
    [David Roth Weiss] “[Ed] “I do it by removing the offending frame and replacing it with the
    Cloning part of a frame from the next or previous frame is the way this is normally done, and there’s a huge difference. The simple way to do this right in FCP is to duplicate a few frames of your bad video and place that on the video track directly below. Now, slide that one frame ahead, or one frame back depending on the best good frame. Now place an oval shaped mask on the top layer and move and size it until it covers your dropout and shows through the top layer revealing the same section of the frame from the good video below without the dropout. Then, place a softedge on the mask and adjust until you’re happy. There are plugins available that do this more easily, and this is certainly quite easiliy accomplished in both AE and Combustion, but its right there in FCP too.”
