Activity Forums Adobe Premiere Pro FCP Veteran has some questions!
  • FCP Veteran has some questions!
    Posted by Sean Morton on July 5, 2011 at 8:49 pm
    Hi Premiere Pro Gurus.
    just migrated to premiere pro. i am enjoying what i am doing. couple of
    quick questions.
    1. when you gang reference window to Program windows. Can scopes
    run in real time in the reference window??. They only move when you
    have stopped.
    2. in fcp you could add effects to your clips in the previews windows
    before entering timeline. is this possible in premiere pro. i could
    only add effects after the clips were in the timeline.
    Sean
    David Cherniack replied 15 years, 1 month ago 3 Members · 3 Replies
  • Chris Knight
    July 5, 2011 at 9:11 pm
    1. Only with jog/shuttle.
    2. No. It’s the same workflow in After Effects as well. It is, however, possible to do this via Photoshop and Dynamic Link, but it’s an odd workaround for most situations.
  • Sean Morton
    July 5, 2011 at 9:16 pm
    Thank you so much for responding
    so quick. I thought i had shut
    something off for the first question
    i had.
  • David Cherniack
    July 5, 2011 at 9:29 pm
    [Sean Morton] “when you gang reference window to Program windows. Can scopes run in real time in the reference window??”
    I’ve found that when monitoring the program on an external monitor via my Matrox MXO2 LE and changing the program monitor to waveform scope that it runs in real time. This is on a 8/16 core workstation. I haven’t tried ganging a reference monitor as a scope.
    My main complaint with the Premiere scope is that it doesn’t show the super whites & blacks that can be in the SDI signal – Matrox driver checkbox.
    David
    AllinOneFilms.com
