Activity Forums Adobe Premiere Pro FCP user wants to know which keyboard shortcut set to use.
  • FCP user wants to know which keyboard shortcut set to use.
    Posted by Mark Morache on August 20, 2011 at 6:58 am
    I see that Adobe has created a shortcut set for FCP users to help smooth out the learning curve.
    I’d like some advice.
    Is there any advantage in forcing myself to learn the default PP shortcuts, because there are similarities in keyboard shortcuts between Adobe aps?
    When I went from Avid to FCP many years ago, I determined to learn the FCP shortcuts rather than try to emulate the Avid keyboard my fingers were used to, and I’m very glad I did. I think it helped me get into the heads of the programmers and their intention for workflow.
    I’m calling it FCX. They took the “pro” out, so I will too.
    I’ll reconsider after the first upgrade.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    blogging at https://fcpx.wordpress.com
    Ben G unguren replied 15 years, 1 month ago 3 Members · 2 Replies
  • Jon Barrie
    August 20, 2011 at 7:17 am
    If you plan to use after effects then yes there are similarities and it is worth learning the default keys.
    The logic in them is mostly quite clear and easy to retain.
    – Jon
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Ben G unguren
    August 20, 2011 at 7:52 pm
    After two months of using Premiere alongside FCP I have added dozens of custom hotkeys, but in general have tried to keep Premiere’s default hotkeys where they are. After about a month, the Premiere hotkeys started to hold their own logic, and when I am cutting in FCP I sometimes find myself preferring the Premiere hotkeys. I’m glad I stuck with the Premiere hotkeys — kept me from pining for the FCP way of doing things….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
