Activity › Forums › Apple Final Cut Pro Legacy › FCP – Update from v6.0 to v6.0.4
  • FCP – Update from v6.0 to v6.0.4
    Posted by Steve Rogers on July 6, 2009 at 6:19 am
    Hello,
    This may seem a simple question for some, however I’m struggling to install the latest version of FCP v6.0.6.
    Is there an easy way of going from FCP v6.0 to v6.0.4?
    I currently have FCP v6.0 running on my MACBOOK Pro and would ideally like to upgrade to v6.0.4 at a minimum (the reason is that I’m trying to open a FCP project file created in FCP v6.0.4).
    I’ve downloaded the latest version of FCP v6.0.6, however the installation is rejected as I need to have FCP v6.0.5 already installed.
    Can someone please let me know if there is a simple way to go from FCP v6.0 to FCP v6.0.4?
    Steve
    Steve Rogers replied 17 years, 2 months ago 3 Members · 6 Replies
  • Zane Barker
    July 6, 2009 at 7:06 am
    Just simply run software update, and keep doing that until there are no more updates left (some updates do require a previous update to be installed)
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Steve Rogers
    July 6, 2009 at 11:22 am
    Thanks for your quick response Zane!
    I don’t see FCP in the list of applications to update (Software Update List).
    Are you saying that I have to update other applications in order for FCP to come up in my Software Update list?
    Steve
  • Zane Barker
    July 6, 2009 at 2:02 pm
    [Steve Rogers] “I don’t see FCP in the list of applications to update (Software Update List).”
    Any chance you have moved the FCP apps so that they are not located they normally are in the Applications folder. For example if you moved them all within another folder inside the applications folder.
    Software update ONLY looks in the Applications folder to see what you have, so if the application it self is not there it will not find it, and software update does not look in the folders that are inside of the applications folder.
  • Scott Sweeney
    July 6, 2009 at 9:08 pm
    I’ve noticed that some of the final cut upgrades show up as “pro applications update” in my software update. Make sure you have that update checked. And make sure your operating system is either 10.4.11 or a more recent version of 10.5
    I’ve been updating all of our machines to 6.0.6 from 6.0 and I noticed that on 6.0.6 I finally saw an updater that actually said final cut pro 6.0.6.
    Just a thought,
    scott
  • Steve Rogers
    July 13, 2009 at 12:11 am
    Scott: Thanks for your feedback… understood. I’ll check my OS and ensure that I check the “Pro Applications Update” option.
    Zane: Thanks for your input… I’ve checked my ‘Applications’ folder and FCP is listed there.
    All: Does anyone know if Apple archive prior release updates for FCP via the apple.com.au download site? i.e. FCP 6.0.1, FCP 6.0.2, FCP 6.0.3, FCP 6.0.4?
  • Steve Rogers
    July 13, 2009 at 1:28 pm
    No need to respond to my previous post… installing “Pro Applications Update” did the job. After the “Pro Applications Update” it prompted to download & install FCP 6.0.6.
    Thanks your input.
