Activity › Forums › Apple Final Cut Pro Legacy › FCP Unreliable Regularly Crashing
John Fishback
June 4, 2010 at 2:25 pmHave you run DiskWarrior as Rafael suggested. It has cleared FCP performance issues many times for me. Also, I assume youtrashed prefs and repaired permissions.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jon Collins
June 4, 2010 at 2:37 pmHi,
Yer I tried DiskWarrior last time with no luck. I haven’t trashed Prefs yet this time, I’ll do that next, but I’m sure I would have done that last time as well.
Just to add to the equation, I’ve now just switched over to work on a new MacPro model (Summer last year issue), running FCP 6.0.6 again and I’m getting the same problem so its not the installation or machine. Project file is still under 1.5mb so pretty small in the grand scheme of things.
As I said before, it can’t be just coincidence that its only when I’m working with multicam clips as I haven’t had this on either machines on any projects I’ve worked on over the last year and this is the first time I’ve used the multicam feature since that last project.
Cheers,
Jon2x 3Ghz 12GB MacPro || 2.33Ghz Core Duo 2GB MacBook Pro || OSX 10.5.7 – FCP Studio 2 – Adobe CS4 Master Collection
