Activity › Forums › Apple Final Cut Pro Legacy › FCP Unexpectedly Quits
Posted by Joe Somodi on May 10, 2005 at 12:05 amWhat are the possible issues surrounding my FCP completely crashing when I am doing a “Print to Video”?
Joe Somodi, Editor
Gryffen Productions
NYCJoe Somodi replied 21 years, 3 months ago 3 Members · 4 Replies -
Joe Somodi
May 10, 2005 at 1:08 amOn top of FCP crashing on me, I am consistatly getting “dropped frames” message. (I posted an earlier message regarding this issue) I am aware of many of the things that one can do to avoided this dreaded error message:
– closed unused sequences
-trash pref
-not have any drive more than 90% full
– do a mixdown on audio
etc etcI’ve even Rebuilt my permissions on my hard drive several times and this doesn’t seem to do any good.
I’m at a loss….
Any ideas?
Many thanks,
Joe Somodi, Editor
Gryffen Productions
NYC -
Jeremy Garchow
May 10, 2005 at 3:48 amWhat are your system specs? G4, G5? Capture card? Media drives? Anything else hooked up to your machine? Sounds like a configuration issue. Give us some more to work with and we’ll try to help.
AJA Kona2>HD10C2>D10ADecklink Extreme
Joe Somodi
May 10, 2005 at 5:13 pmI am running the G4, Duel 800, I have three extra media drives (IBM – 120gigs) and one external LACIE drive (150gigs). I have a scanner and a printer hooked up to the computer and out of the firewire I’m running the SONY DSR-11 deck. I’m really confused if it’s a config issue, since I’ve had this set up the same way for the past three + years – with few issues. I upgraded my RAM about a year ago and now have two new 512’s in their along with an original 512 (so three total) and since I’m totally lame I have no idea what the name of my firewire card is. (guide me to where i can find the name)
I will try lowering the RT audio to 2 and see what happens, but it seems to be a LARGER issue than a small adjustment b/c
1. it’s happening on a regular bases (and i edit almost every day)
2. for FCP to simply shut down while in a “print to video” mode seems highly irregular – and reads that the system is unstable…I did upgrade my OS system recently to 10.3.9 and I did upgrade FCP recently to the HD version…this could have something to do w/ it?
your help is so appreicated
joe
Joe Somodi, Editor
Gryffen Productions
NYC
