Activity Forums Apple Final Cut Pro Legacy FCP unexpectedly quits
  • FCP unexpectedly quits
    Posted by Peter Rooney on May 26, 2005 at 7:38 am
    I can’t shift this problem.
    G4 500 MHZ, 768 Ram, 4.5HD, 10.3.9, QT 6.5.2 Pro. Upon capture, double-clicking the clip in the browser, causes the beachball, then FCP quits. Trash prefs, restart FCP, double-click the clip in the browser and it’s all fine.
    I get the same quit if I drag a clip to the canvas immediately after capture, it has to ‘quit’ I have to trash the prefs, restart before it’ll allow me to use my clips.
    Did complete re-build of HD, system, QT, FCP etc, all VERY well managed HDs and I’m not capturing to my boot drive but to another internal 7200 IDE drive.
    Peter Rooney replied 21 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    May 26, 2005 at 9:55 am
    I think your problem *might* be 10.3.9… I’m staying on 10.3.8 with my FCP HD system as AJA’s Kona 2 card still isn’t working well in 10.3.9, and with DV captures, I don’t see your problem… also it’s unwise to go to QT 7 BTW with Panther setups and FCP I think.
    So an archive and install of Panther and update only to 10.3.8 might just fix you right up. I think the combo updater to 10.3.8 is on Apple’s site. QT 6.5.2 is OK…
    Jerry
  • Peter Rooney
    May 26, 2005 at 10:07 am
    Thank you Jerry, I’ll have to give that a go as it’s just like being in OS 9 all over again.
    Peter
  • Peter Rooney
    May 30, 2005 at 2:59 pm
    Hi jerry, rolled back to 10.3.7, clean re-instal of everything, can’t shift this at all. I’ll try the Apple discussions.
    Peter
