Activity › Forums › Apple Final Cut Pro Legacy › FCP Tool Palette & Audio Meter Is Gone
  • FCP Tool Palette & Audio Meter Is Gone
    Posted by Scott Gray on May 9, 2005 at 9:14 pm
    Although I can check and uncheck both the tool palette and audio meters in the Window column, they will not display on my monitors. This problem began after I loaded the new Tiger OS. An thoughts?
    Bret Williams replied 21 years, 4 months ago 3 Members · 2 Replies
  • First step is to quit and re-start the Mac and FCP.
    Next to try would be to Trash the FCP Preferences.
    Click the following link for instructions on how to do this…
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    Another method is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP & FCE.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
  • Bret Williams
    May 9, 2005 at 10:29 pm
    Also just simply try choosing a preset window workspace like standard. Tiger might have messed with your screen sizes/arrangement and the window could simply be off screen.
