Activity › Forums › Apple Final Cut Pro Legacy › FCP & Toast 11 Pro won’t burn Blu-ray disc
  • Douglas Farrelly
    November 12, 2011 at 7:23 pm
    [Douglas Farrelly] “As we speak I’m half way through burning a BD-R, so fingers crossed. I’ll let you know how it goes when it’s finished.”
    Hi guys, just wanted to update you: Turns out that I can’t burn BD-R’s using Toast, I can however burn them on the pc using Adobe and also the software that came with the Plextor burner.
    I’m still waiting for Roxio to get back to me. 🙁
  • Ken Barnes
    November 7, 2012 at 11:09 am
    Hi Steve,
    This is an old post but if you’re still getting replies, I have a question since you’re a Matrox person. (Matrox Customer Support is rubbish)
    I have Matrox MX02 Max. I used compressor to make a .264 file (there is no ‘h’ before the period in the file) However, nothing accepts this file. Neither toast, nor encore, nor matrox vetura playback.
    I just want to burn a BluRay disk with the 18gb file. Toast says the .264 file is “an unsupported format and cannot be imported”
    I tried custom settings in the encode window in Toast 11.04 but no joy.
    Any ideas? Which Compressor>MatroxMX02> settings do you recommend? What is the final format that Toast will accept?
    Thanks, Ken
    ‘It’s not a question of becoming. It’s a question of uncovering what you really are, of letting everything that is not yourself fall away’. – Journey to Ladakh
    I think this applies to editing as well….
    Ken Barnes, Producer, Director, Editor
    http://www.blissmonkeyfilms.com
  • David Eaks
    November 7, 2012 at 12:58 pm
    Hi Ken,
    Do you have Chapter Markers in the video file? Toast won’t accept files encoded with Matrox MAX if it has chapter markers.
  • Ken Barnes
    November 7, 2012 at 7:02 pm
    Yes I had Chapter Markers. Perhaps that’s the culprit!
    I ended up making a m2v in Compressor using Blue Ray settings. It was accepted fine. I wonder if there’s any difference in quality between what Matrox can do and this method? Matrox is definitely faster.
    I’m going to try a Matrox version without chapter markers now. I’ll let you know how it goes.
    Thanks a lot!
    Ken
Page 3 of 3
