  • Posted by Frederic Menou on April 30, 2010 at 3:26 am
    Help!
    Hello all,
    I finished a project on FCP (footage shot on dvc pro hd (720)), and I am trying to export it to a web site for clients to see. It looks great on FCP, but when I export it to Quicktime and then to the web page, the look changes: the blacks and the midtones are milky, the color correction done in FCP doesn’t match the web version… It’s important that I get the best picture quality since I am a DP and the web site would be for clients to see.
    What is your suggestion to get the best the quality on my web page? What settings? Is there a way for my fcp footage to match the final web version? Also should I worry about file size for downloading vs quality? Is there a compromise?
    Thank you all so much for your much awaited answers.
    Dennis Radeke replied 16 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Amir Abed
    April 30, 2010 at 3:42 am
    What were you exporting as?
  • Rob Grauert
    April 30, 2010 at 4:19 am
    I made a tutorial for web exports a number of weeks ago:
    https://www.youtube.com/watch?v=uTUsA7Em1Ug
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Frederic Menou
    May 3, 2010 at 4:46 pm
    I was using the quicktime conversion to export…
    I tried Rob settings but the picture feels a bit jumpy and there is a loss of quality that is noticeable… I am going to try a variety of settings…
    What do you guys think the maximum file size of the quicktime movie should be, so that people with a good to average internet connection can watch with no buffering time?
    F.
  • Rob Grauert
    May 3, 2010 at 5:15 pm
    when you’re compressing for the web, file size isn’t the most import part; it’s data rate – the rate in which data is transferring.
    So for a video to buffer without interrupting playback, the data of that video must flow to your end user slow enough for their internet connection to handle it. make sense?
    For Quicktime, I usually go with 750 to 1000 kbps, but you can go much lower with Flash and maintain nice quality, as well as reach a wider audience.
    sorry my tutorial didn’t work for you, btw. it works for me everytime
    Rob Grauert, Jr.
  • Frederic Menou
    May 3, 2010 at 5:16 pm
    Thanks Rob. I am going to try that.
  • Walter Miale
    May 14, 2010 at 5:52 pm
    I didn’t catch the instructions re exporting for Flash.
    I presume that will provide the most universally playable format, yes?
    Do I export a reference QT from FCP and then use Compressor to compress it to H.264, and afterward just change the extension to .flv?? Or what?
  • Rob Grauert
    May 15, 2010 at 12:07 am
    Yes, Flash is best if you want to reach the widest audience. This is how i’d convert to Flash:
    1. Export a full quality, self contained Quicktime out of FCP. (File > Export > Quicktime Movie)
    2. Bring that new file into Adobe Flash converter to compress for the web.
    or
    Bring that new file into Sorenson Squeeze to compress for the web.
    Unfortunately it’s not as simple as just changing the file extension, as far as I know.
    Rob Grauert, Jr.
  • Dennis Radeke
    May 15, 2010 at 11:17 am
    Another approach if you have Production Premium is to use the Adobe Media Encoder. This would give you many more encoding options.
