Activity › Forums › Apple Final Cut Pro Legacy › FCP to Soundtrack Roundtrip not working
  • FCP to Soundtrack Roundtrip not working
    Posted by Josh Sapir on December 8, 2010 at 12:59 am
    Hey all, wanted to see if anyone else has experienced this problem and if anyone my have found a solution.
    I am editing a short video with sequence settings (960×720, 23.98, ProRes 422) FCP version 7.0.3, Soundtrack version 3.0.1
    My first bit of trouble occurred when I: Right clicked > Send to > Soundtrack Pro Audio File Project and encountered the “the render.mov file cannot be opened.” warning. I dumped my preferences and re-rendered the timeline and after some trouble was able to get the audio file to finally open in Soundtrack.
    The second problem occurred after I applied my effects within Soundtrack, saved the file (reference source audio), and went back into FCP. Final Cut crashed immediately with this problem report:
    Process: Final Cut Pro [3704]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 7.0.3 (7.0.3)
    Build Info: FCPApp-1008261348~8
    Code Type: X86 (Native)
    Parent Process: launchd [143]
    Date/Time: 2010-12-07 17:39:02.455 -0700
    OS Version: Mac OS X 10.6.5 (10H574)
    Report Version: 6
    Interval Since Last Report: -81197 sec
    Crashes Since Last Report: 3
    Per-App Interval Since Last Report: 80390 sec
    Per-App Crashes Since Last Report: 9
    Anonymous UUID: A6B42212-1000-44A3-B0F0-945B41225602
    Exception Type: EXC_ARITHMETIC (SIGFPE)
    Exception Codes: EXC_I386_DIV (divide by zero)
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 …ickTimeComponents.component 0x91df9193 TimeCodeFrameNumberToTimeCode + 145
    Console Reads:
    12/7/10 5:38:45 PM Soundtrack Pro[3740] WARNING: -[NSProVideoTimecode setCustomVideoFrameRate:] passed invalid frames per second: -0.000000. Using 30 fps.
    I have set and reset my project settings in Soundtrack to reflect the 23.98 sequence. Trashed preferences in Soundtrack and FCP several times. Re-installed Soundtrack. Dumped any and all 3rd party audio filters. Moved my FCP sequence into a new project and nothing seems to work.
    Any ideas? Is this a fps issue like I think it is? Do I have a corrupt file somewhere?
    Thanks in advance,
    Josh
    Mac OSX 10.6.5, Processor 2×2.66 GHz Dual-Core Intel Xeon, 4 GB 667 MHz DDR2 FB-DIMM
    Josh Sapir replied 15 years, 9 months ago 2 Members · 3 Replies
  • Michael Gissing
    December 8, 2010 at 2:21 am
    Whilst the error report suggests a frame rate problem, 920 x 720 is an unusual frame size. Just to try, chcange Easy Setup to 1920 x 1080 ProRes422 23.98. Copy>paste just the audio into the timeline. Try an export to STP from a bog standard 23.98 timeline without the added complication of pics.
  • Josh Sapir
    December 8, 2010 at 4:37 pm
    I will definitely try a different sequence setting once this message “The document “render.mov” could not be opened.” stops popping up.
    Josh
  • Josh Sapir
    December 8, 2010 at 6:37 pm
    Just an update. I am now confident the problem is not with Soundtrack but with FCP. I opened another project that has the same settings, sent out to soundtrack and round-tripped with no issues.
    I think there must be an issue with a clip within the timeline.
    I even exported an XML and re-imported into a brand new project and still had FCP crash.
    Not sure it is worth going through the sequence clip by clip to find the problem.
