Activity Forums Apple Final Cut Pro Legacy FCP to Quicktime issue
  • FCP to Quicktime issue
    Posted by Tony Fields on June 18, 2010 at 4:12 pm
    I have an iMac (sorry that I don’t have the specs, as it is my home system and I’m, at work)and the problem that I’m facing is that when I export my FCP to Quicktime, ir doesn’t save as a QT Movie file, it saves as an FCP movie file. How do i fix this?
    Tony Fields replied 16 years, 3 months ago 4 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    June 18, 2010 at 4:20 pm
    Right click on the file and choose Open With > Quicktime.
    jeremy
  • David Roth weiss
    June 18, 2010 at 4:21 pm
    They are one and the same, with both carrying the .mov suffix, the only difference being the icon they carry and the fact that those exported as self contained QTs from FCP want to automatically open in FCP on your on your FCP system. Simply right click and tell those files to use QT Player instead if you want to view them. otherwise they work in all other apps exactly the same as any other QT file.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Steve Walker
    June 18, 2010 at 4:30 pm
    I’m using FCP 7 and it’s as simple as ‘File-Export-Quicktime Movie’, of course you could always ‘Send To-Compressor’ if you have that installed.
    Steve Walker – MacBook Pro, 3.06 GHz, 4 GB Intel Core Duo, Lacie sata II express card w/ 2TB Lacie Quadra, MIDI from M-Audio Firewire 410. FCP 7, Logic Pro 9
  • Tony Fields
    June 18, 2010 at 5:11 pm
    ok. if I want to give the files to someone else in QT format (who doesn’t have FCP), how do I change it, or do I need to?
  • Jeremy Garchow
    June 18, 2010 at 5:26 pm
    [Tony Fields] “how do I change it”
    I think if you reread the posts, you have your answer. The other problem you might have, though, is that the receiver might not have the proper codec. What is the codec of your timeline?
  • Tony Fields
    June 18, 2010 at 5:46 pm
    i need to check that (I did the project on m home system and I’m @ work)
  • Tony Fields
    June 18, 2010 at 5:47 pm
    When I “Open with” QT player, it only gives me an audio track.
  • Jeremy Garchow
    June 18, 2010 at 5:49 pm
    [Tony Fields] “When I “Open with” QT player, it only gives me an audio track.”
    Because you don’t have the codec. Hit command-i to bring up the info while the movie is open in QT.
  • Tony Fields
    June 18, 2010 at 6:13 pm
    the codec info is not there
  • Jeremy Garchow
    June 18, 2010 at 6:29 pm
    Hit command-I with Quicktime open, not from the Finder. A little grey dashboard should open and look where it says ‘Format’
