  • Posted by David Ertley on March 9, 2009 at 5:49 am
    I have finished my first movie in FCP, sent it to color and back, and had the audio mastered in 5.1 in Pro Tools. I want to play it on a projector in HD, so I decided to play it off of my PS3 being it’s Much easier to carry than my G5. I exported an h.264 from compressor with 5.1 sound, but the PS3 wouldn’t play it (claiming it’s corrupt). What is the way to make this work?
    Jeff Gates replied 17 years, 4 months ago 6 Members · 9 Replies
  • 9 Replies
  • Evan John
    March 9, 2009 at 2:29 pm
    What was your method of burning, and what kind of disc did you burn it to?
  • David Ertley
    March 9, 2009 at 3:15 pm
    none, I put the quicktime on a CF card, I also tried streaming it over the network.
    https://davidertley.com/
  • Russell Lasson
    March 9, 2009 at 4:10 pm
    I’ve had very little luck with the PS3 playing back large H.264 files. I think there are two main problems. First, file shouldn’t be larger than 4GB and second, it needs to be a mp4 or m4v file. You might try compressing it using an AppleTV preset. I think that worked once. But the PS3 is much more picky than I expected it to be.
    -Russ
    Russell Lasson
    Universal Post
    Ridgeline Digital Cinema Mastering
    Salt Lake City, UT
  • David Ertley
    March 9, 2009 at 4:25 pm
    Will the AppleTV preset let me export it in 1080i with 5.1?
  • Russell Lasson
    March 9, 2009 at 8:07 pm
    Don’t know. But in compressor, there is a place under the appleTV settings that says, “Include Dolby 5.1”. Not sure how it works, but you should play with it.
    -Russ
    Russell Lasson
    Universal Post
    Salt Lake City, UT
  • Winston A. cely
    March 9, 2009 at 8:42 pm
    I’ve actually been playing with this just with trailers I downloaded in 1080p from Apple’s website. The 5.1 audio works great when using the Appl TV preset, but I haven’t been able to get it to export in 1080p or have 100% success. Sometimes they play and sometimes they won’t. Very frustrating.
    Winston A. Cely
    Editor/Owner | Della St. Media, LLC
    Mac Pro 3GHz Dual-Core Intel Xeon
    4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
    “If you can talk brilliantly enough about a subject, you can create the consoling allusion it has been mastered.” – Stanley Kubrick
  • Jeff Gates
    March 12, 2009 at 1:51 pm
    I have done much testing and finally come up with the best ways to export to PS3.
    You can export to an HD MP4 file from compressor and make it work on a PS3, but only stereo audio will play.
    The best way to get a file into the Playstation 3 in HD is to encode the Video in compressor to a Blu Ray MPEG-2 video file and encode the audio to ac3. Now that you have the 2 seperate files you will need to mux them together into a M2TS stream. This can be done using the tsMuxeR program that is freely downloadable on the web.
    That’s it.
  • Rob Grishow
    May 22, 2009 at 1:12 am
    If you send your Sequence to Compressor and choose the MPEG2 Program stream, it works just fine on the PS3.
  • Jeff Gates
    May 22, 2009 at 3:31 pm
    Yes, that will work. 5.1 audio will not.
