Activity › Forums › Panasonic Cameras › FCP to P2
FCP to P2
Posted by James Mulryan on July 15, 2006 at 10:45 pmCan you transfer a FCP DVCPROHD project back onto a p2 card connecting your HVX via firewire?
Lars Wikstrom replied 20 years, 2 months ago 3 Members · 3 Replies -
Barry Green
July 17, 2006 at 6:15 amYes, you can “print to video” back to the card. Make sure the camera’s in the same mode as your timeline (i.e., 1080/60i or 720/60p) and put it in MCR mode, and turn off the thumbnails, and turn off device control. Then you should be able to see your timeline scrubbing on the camera’s LCD; just “print to video” and press the two MCR RECORD buttons (above the menu navigation buttons) and it’ll record the incoming firewire stream.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
James Mulryan
July 17, 2006 at 2:39 pmThank you Barry. Great info. Can’t wait to get you book at the L.A. Bootcamp.
Lars Wikstrom
July 17, 2006 at 4:54 pmHey Berry, you helpeed me with this same problem. I couldn’t get it to work for a long time and then discovered that the camera, like you mentioned here, has to be set to the same record settings as your time line. I had an HD timeline that I wanted to output but the last thing I shot was a 480i and that is why the camera print to video didn’t work. I had go go back into the camera and set it back to 720p then it worked
-Lars
