FCP to Monitor via Kona card
My goal is to simply monitor video out from Final Cut Pro.
I am using an Aja Kona LSe card and BOB.
I am able to see color bars in the monitor when I select the Test Pattern on the Kona Control Panel, but when I select Input Passthrough I get static.
My connections are: Mac with Kona card to BOB via SDI. BOB SDI out to monitor SDI in. I have also bypassed the BOB going directly from the Kona card to the monitor and have had identical results.
I’ve checked the “Audio/Video Settings”and the “Sequence Settings” in FCP and they seem to be correct, but I’m guessing that’s the source of the problem.
Would appreciate suggestions. Thanks!
