Activity Forums Adobe After Effects FCP to Keylight to FCP problem
  • FCP to Keylight to FCP problem
    Posted by Robert Buncher on July 6, 2008 at 11:18 pm
    I have shot test footage in DVCPRO HD 1080p24A captured in FCP. I imported the file in to AE and keyed it in Keylight. The key looked great. I followed the instructions from the book, “After Effects Apprentice.” I rendered the file out as Animation + alpha. In FCP I then had to render back to DVCPRO HD.
    The key still looks good except that it has a thin, even line that runs around the keyed subjects much like the outline of a cartoon. The line separates the keyed area from the background.
    This is such an odd thing that I must have some very simple thing wrong. What could it be?
    The color space is set to none.
    On a related question, in reading the back threads on Keylight problems, I came across the statement that it was best to bring the files to be keyed directly into AE before they are put into FCP. Is this a true statement? Does it mean that I would import the file from the capture scratch file and, after keying and rendering in AE, import it into a new FCP project and render to that projects properties?
    Bob
    MacbookPro 2.33 2gb os 10.4.11
    FCP 5.1.4 After Effects Bootcamp XPpro
    Robert Buncher replied 18 years, 1 month ago 3 Members · 4 Replies
  • Brendan Coots
    July 7, 2008 at 4:57 am
    First of all you really should, if at all possible, complete your composite in After Effects rather than bringing the keyed shot into FCP to add in your background. After Effect’s tools for doing composites are much more advanced and you will get a cleaner result due to other issues. You will also have way more control over things like matching up the lighting, adding in details to help “sell” the shot etc. Even if you don’t plan to do a lot of advanced compositing, you will get a usable result much easier in AE.
    That said, the reason you are seeing a fringe around your actor is because you need to render from AE using the “Straight” alpha type rather than premultiplied which is the default – once you select millions+ in your render settings, you can change the alpha type.
    Note that anything you render with a straight alpha will look really screwy in Quicktime player, but it will import into your apps properly.
    “I came across the statement that it was best to bring the files to be keyed directly into AE before they are put into FCP.”
    Since you are shooting DVCPRO HD I will assume you are using an HVX200 or similar camera. If that is the case, then you don’t really have anything to lose using FCP to ingest the footage. Ingesting footage will not result in generational loss, in this case it is merely converting the video/audio data from the MXF “essence” files into a usable codec, but it doesn’t degrade quality in the process. The only alternative would be pulling your MXF files directly into AE which is detailed in this Adobe document. Can’t say that I’d recommend this approach but others who have done it more than I may have more insight into this approach…
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Robert Buncher
    July 7, 2008 at 11:23 am
    Brendan,
    Thank you for the response.
    I will try to devise a work flow that would allow me to do all the compositing in AE. That sounds like a good idea.
    I did have the alpha set to straight so that could not be the culprit.
    The footage came from an HDX-900 so they were not MXF files.
    Bob
  • Tim Kolb
    July 8, 2008 at 4:25 pm
    I always test my greenscreen keys in front of multiple colored backgrounds when I’m prepping an alpha channel output for say, a stock shot that will be distributed as an alpha transparent clip. only seeing the quality of your key against white or black won’t necessarily show you all the edge issues as anything that blends with the background will not be apparent. I usually create several layers with solids that are white, black, medium gray, magenta, yellow, and cyan…probably a little overkill, but I catch an amazing amount of little issues that way…
    However, to echo what Brendan already said, completing the composite in AE is still the best way to make sure you have a well-integrated composite.
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Robert Buncher
    July 8, 2008 at 7:01 pm
    Tim,
    Thanks for the insight.
    Bob
