Activity › Forums › Apple Final Cut Pro Legacy › FCP to IPOD for Client reviews
Posted by Ashley James on January 26, 2007 at 3:57 pmI’m using FCP – and my IPOD to bring video for review to clients on a tv monitor. I’ve tried exporting using Quicktime Conversion>IPOD codec and Quicktime Pro 640×480 for higher rez exports. When completed after ITUNES i/o we simply plug the IPOD into a tv using a cable. The IPOD codec has smooth motion but pixelated when showing fast movements. Also the quality of the overall video was low. With the 640×480 codec the quality was higher but the movement was not smooth. It stuttered. Does anyone have a formula that will give me higher rez with less compression and smooth moves? Is there a way to uprez the IPOD codec in FCP?
Travis Ballstadt replied 19 years, 8 months ago 6 Members · 11 Replies -
Mark Maness
January 26, 2007 at 4:04 pmUse Compressor. This program was built specifically for this type of work.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Delano Bryant
January 26, 2007 at 5:52 pmAmen to that brother! I don’t know why everyone isn’t using compressor. Unless you’re saving time for an output to view, then use compressor.
Jeremy Garchow
January 26, 2007 at 8:07 pmThe ipod was not made for television, it was made for the iPod. The resolution you are getting when you go to iPod is 320×240. That’s half of tv res. No wonder you are seeing pixelation, no? And as far as stuttering, the iPod was created for 320×240 video, it probably can’t keep up with 640×480 video.
Be archaic and burn a DVD or present it on your laptop. If they have a projector, hook up your laptop to the projector for greater resolution.
Jeremy
Tom Wolsky
January 26, 2007 at 9:28 pmIt depends on which generation iPod.
Compressor is still using the first generation viPod settings of 320×240. Direct export from FCP uses the current viPod settings of 640×480. This is used for movie downloads from Apple and works on current gen viPods.
I’ve been using Episode to encode 640 horizontal with 16:9 aspect format video for iPod and the quality is pretty good. I also like to compress to using 480 horizontal for 16:9. It seems a good compromise of file size for image quality. Works fine on the current gen viPod. Content is a huge factor on how well this stuff encodes. Movement often encodes quite poorly.
Ashley James
January 26, 2007 at 10:41 pmI have a new 30 GB Video Ipod and I used the IPOD selection when I output from FCP. However, on analysis it says its 320×240, not 640×480. I did explore Compressor as the first replies suggested (thank you very much) It says the export from FCP is at 23.98, although I didn’t set that up. Shouldn’t the frame rate be 29.97 or 30 fps? Could that be the jerky motion problem?
Ashley James
Tom Wolsky
January 27, 2007 at 4:32 amWhat version of FCP is this?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Tom Wolsky
January 27, 2007 at 4:33 amAnd what version of QuickTime is this?
All the best,
Tom
Ashley James
January 27, 2007 at 9:51 amIts the frame rate. Looking at the exported quicktime in Compressor the frame rate somehow was 23.98 I was successful getting an excellent 640×480 with proper motion Burned a dvd of the fcp quicktime, used Handbrake and selected 29.97 as a frame rate and average bitrate of 1500. Hooked it up to a monitor and it was very nice. Not quite dvd quality but very nice. I’ll try experimenting with Compressor when I can get to the media but frame rate was the culprit
Thanks to all
Tom Wolsky
January 27, 2007 at 9:56 amWhat version of FCP and QuickTime is this? I’m not seeing the results you’re getting. What is the original material you’re working with and what are the sequence settings?
All the best,
Tom
