  • Posted by Adi Ell-ad on December 17, 2009 at 2:59 pm
    Aloha,
    I am running FCP on a MacBookPro.
    Looking into an HDMI monitor solution.
    What is the best?
    AJA Io Express
    Vs.
    Matrox MXO2 Mini
    Is there anything else out there?
    Adi
    Adi Ell-ad replied 16 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    December 17, 2009 at 8:52 pm
    [Adi Ell-Ad] “What is the best?
    AJA Io Express
    Vs.
    Matrox MXO2 Mini “
    MXO2 mini has a leg up here as it can balance the monitor to bars via HDMI. The AJA cannot. The MXO2 mini is also cheaper.
    [Adi Ell-Ad] “Is there anything else out there? “
    MOTU HDX-SDI. And the IOHD…but that is far more expensive than the IP Express….and doesn’t work with COLOR.
    Shane
  • Tony Brittan
    December 18, 2009 at 12:28 am
    I have the MXO2 and absolutely LOVE it! Anything I’m the MXO2 family is what I’d recommend.
    Tony Brittan
    Apple Certified Pro – FCP
    islandshoreproductions.com
  • Gary Adcock
    December 18, 2009 at 4:29 pm
    [Shane Ross] “MXO2 mini has a leg up here as it can balance the monitor to bars via HDMI. The AJA cannot. The MXO2 mini is also cheaper. “
    Not true Shane,
    All aja products have the ability to output Bars via any of the outputs.
    All you need to do is set the Kona Control to output Bars and it will.
    the only caveat is you need to have the Kona control panel app in the foreground.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Adi Ell-ad
    December 18, 2009 at 4:31 pm
    Thanks for all the info. This really helps.
    I am liking the MXO2 and the price.
    Did anyone calibrate a TV set with the AJA Box?
    Adi
  • Shane Ross
    December 18, 2009 at 5:17 pm
    [gary adcock] “All aja products have the ability to output Bars via any of the outputs.”
    That wasn’t what I meant Gary. The MXO has an INTERNAL calibration tool. You can adjust chroma, contrast, brightness so that you can balance the monitor…properly calibrate it to bars. The AJA products don’t do this…they rely on the monitors ability to do this.
    Shane
  • Mario Rubertis
    December 20, 2009 at 2:33 pm
    Adi,
    I have the MXO2 and love it!
    If all you need is a HDMI monitoring solution then you found the right one with the MXO2 Mini. I’d recommend getting the one with H.264 encoding built in. It runs for $850 …. still less expensive than the AJA box.
    An Artist At Heart.
    Life is made of moments…
  • Adi Ell-ad
    December 20, 2009 at 2:45 pm
    Thank you Mario. I am thinking after hearing all of you guys the MXO2 is the winner.
    I can do the H.264 from FCP. Is it better with the MXO2?
    Adi
