Activity Forums Apple Final Cut Pro Legacy FCP to FTP compression help
  • FCP to FTP compression help
    Posted by Zeliha Bozkurt on October 25, 2007 at 12:51 pm
    Hi All
    I work for a post house and we often need to FTP the programmes to the relevant channels.
    Programmes are edited with FCP 5 using DVC PRO-HD 29.97 codec (7.6MBpsec.)
    Programmes average 1 hour and need to be delivered in MOV or WMV format – 150MB max file size and 320×180 min. dimensions.
    What is the best way I can get this exported and delivered as quickly as possible?
    Zee.
    Bob Cole replied 18 years, 10 months ago 4 Members · 5 Replies
  • Walter Biscardi
    October 25, 2007 at 1:19 pm
    Export a reference movie from FCP.
    Take than into Compressor
    Set up the proper frame size you need and you can set a Maximum File Size in there.
    It’s going to be a pretty highly compressed file as 1 hour down to 150MB is going to be pretty small.
    but you can adjust and tweak the settings to your heart’s content to find the sweet spot between too much compression and the maximum file size. Once you have that, save the settings so all you have to do is apply it in the future.
    Walter Biscardi, Jr.
    Stop Staring Start Grading with Apple Color The new Color Training DVD now available!
    https://store.creativecow.net/p/66/stop_staring_and_start_grading_with_apple_color
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Zeliha Bozkurt
    October 25, 2007 at 3:45 pm
    Hi Walter
    Thank you for the reply. I have used Compressor in the past, but I find it takes a long time to compress anything.
    Is there something like external encoding card you can reccomend the would do compress it much faster.
    Zee.
  • Walter Biscardi
    October 25, 2007 at 3:48 pm
    [Zeliha] “Is there something like external encoding card you can reccomend the would do compress it much faster.”
    Nope. The hardware solutions I’ve seen run into the thousands of dollars and not worth it for what we do. You can certainly research that to see if anything would fit your budget.
  • 13 Create COW Profile Image
    13
    October 25, 2007 at 7:34 pm
    [Zeliha] “I have used Compressor in the past, but I find it takes a long time to compress anything.”
    Well I have no Idea what kind of system you have because your profile douse not say, but if your computer has multiple processors and or multiple cores make sure you configure qmaster to be able to utilize all of them for maximum performance with compressor.
    Here is a video I recently watched about how do do that.
    https://pixelcorps.tv/macbreak89
  • Bob Cole
    October 26, 2007 at 5:41 am
    You may need two computers.
    I use a Digital Rapids card which encodes very small files in real time. I just make a Quicktime in FCP, reimport it into FCP, and then play it out via my AJA card’s S-video outputs into the Digital Rapids card, which lives in a HP computer.
    I’m sure this isn’t the only solution, but the cost is fairly low, especially if you have a spare PC lying around. (I’d like to learn how to use this card better, so buy one and then tell me what it can do.)
    DRC-500 https://www.digital-rapids.com/Products/IndividualProducts/DRC-Stream%20500.aspx
    My card doesn’t have machine control, which makes it a lot cheaper. But you can get the same card with more sophisticated software and RS-422 control.
    Good luck.
    Bob C
    MacPro 2 x 3GHz dualcore; 2 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
