Activity › Forums › Apple Final Cut Pro Legacy › FCP to FLV file
  • Christopher Targia
    May 28, 2010 at 3:27 pm
    Export as an H.264 file with AAC Audio, as quicktime conversion. Then change the file extension to .flv. This works flawlessly! If you will be doing this alot I would recommend the el Gato TurboHD, its a USB drive you plug into your computer and contains a program that pumps out H.264 files very fast! I use it all the time, all of my editing online and put them into flash this way.
    edit:
    Here is a link to the product-
    https://www.elgato.com/elgato/int/mainmenu/products/Accessories/Turbo264HD/product3.en.html
  • Jean-christophe Boulay
    May 28, 2010 at 3:43 pm
    You could export directly to FLV with Perian (https://perian.org/#download). It will integrate FLV and many other omitted formats to your Quicktime. In FCP, under Export using Quicktime Conversion, you’ll have the choice to export to FLV.
    IHTH
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Laura Williams
    May 28, 2010 at 6:10 pm
    Thanks, but when i exported using quicktime conversion the file was all distorted, very bad quality.
  • Laura Williams
    May 28, 2010 at 6:12 pm
    Will that keep the audio, I was able to successfully change the mov to a flv but when i did that i lost the audio, i will try exactly what you said and see if that works, if it does i will be soo happy, been trying to figure this out since yesterday.
  • John Fishback
    May 28, 2010 at 10:45 pm
    I always export a self-contained QT (not QT Conversion) with Current Settings. Then I use Compressor to make the h.264 from that file. It’s fast if you have QMaster setup to use multiple cores.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
    June 1, 2010 at 1:47 pm
    What John said is probably the best way to do it. I still would recommend elgato’s program if you are going to be doing this alot. It does this same thing faster.
