Activity Forums Apple Final Cut Pro Legacy FCP to DVD Studio problem
  • FCP to DVD Studio problem
    Posted by Michael Noble on December 17, 2007 at 10:58 pm
    I make DVDs all the time but they are 5 to 10 minutes.
    I have a 48 minutes timeline for my kids X-mas play at school and I cannot seem to burn a DVD.
    It is DV/NTSC timeline, I am exporting it as a QuickTime Movie, self contained. Sequence settings match, I have 15 gig on my operating system and but I am using an external Hard Drive 56 GB – USB.
    I am getting to 1.91 GB on the
    export and then makes av.1 and av 2 files up to 6.
    I am going crazy trying to figure out why I cannot export properly? Thank you and God Bless for any help.
    I am using compressor now fastest encode 4:3 90 minutes.
    -Mike
    David Roth weiss replied 18 years, 9 months ago 2 Members · 3 Replies
  • David Roth weiss
    December 18, 2007 at 1:45 am
    [RattleItFilms] “Thank you and God Bless for any help.”
    Mike, I need all the blessings I can get so…
    The problem that your hard drive is formated as FAT32, when it should be Mac Extended. FAT32 has a file size limitation. In order to fromat the hard drive properly you would first have to copy all the files to another drive, then use the Apple Disk Utility in the Applications folder to “Erase” the disk and format as “MAC Extended.”
    Your hard drive is very full as well, you might consider going to Staples or Office depot and getting a bigger firewire drive, as they are very, very inexpensive now. If you do, make certain that you format it properly to Mac Extended before moving any files to it, or you will encounter the same issue that you’re having with your other drive.
    Good luck and thanks for the blessings,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Michael Noble
    December 18, 2007 at 2:50 am
    David,
    Thank you, you are an ace! I am taking you and your friends to “Your” sushi spot when I am back in LA.
    -Mike
    Rattle It Productions
  • David Roth weiss
    December 18, 2007 at 3:00 am
    Anytime!!! I’m always hungry for sushi…
    David Roth Weiss
    Director/Editor
    Los Angeles
