Activity Forums Apple Final Cut Pro Legacy FCP to DVD conversion
  • FCP to DVD conversion
    Posted by Abhishek Sharma on March 9, 2009 at 12:19 pm
    Hi this is Abby.I have a project on Apple FCP.the size of the project is around 20 GB.I have to make a DVD of that project.So how should i compress the size of my project from 20 GB to 4 GB(The capacity of a DVD).Can it be done on FCP only?.I also want the quality to be good after the DVD is made.So Plz suggest me some tips for that.
    Abby.
    Abhishek
    Dino Vince replied 17 years, 6 months ago 3 Members · 2 Replies
  • Rafael Amador
    March 9, 2009 at 12:37 pm
    Hi Abby,
    You can do it with FC and Compressor.
    Export your movie from FC with the highest quality that you can.
    Then you need to convert the QT movie in an MPEG-2. You do that in Compressor. You have there the presets according with the length of your movie and the quality you want to get.
    Then you need to bring those files to DVDSTP to make the DVD.
    Every step is very well explained in the manuals of each application.
    Cheers,
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Dino Vince
    March 9, 2009 at 5:13 pm
    DVD Studio Pro also has built in compression. Export your movie using Final Cut–Export Quicktime Movie under the file menu. Bring that movie into DVD Studio Pro, by opening DVD Studio Pro, going to graphical tab, deleting the default menu and track that’s there, then dragging your Quicktime movie into it. Control click your Quicktime movie to make it ‘first play’ and autoplay…then click ‘Burn’…woila…your movie is compressed, then burned onto a DVD.
