Activity › Forums › Apple Final Cut Pro Legacy › FCP to DG FastChannel
Posted by Chip Whiting on June 7, 2007 at 9:51 pmDoes anyone have to send finished commercials to DG FastChannel? If so, what is your worlflow? How do you make the correct filetype. What program do you use to get to these specs? Compressor, Cleaner, MPEG2 Works 4, BitVice? I’m old school and am used to making dubs, this stuff is confusing!
Here’s what they require.
Video: 18Mbs, MPEG 2 Program Stream, 4:2:2, 9 frame GOP, 29.97 FPS, 4 by 3 Aspect Ratio, 720 x 480 (recommended)
Audio: MPEG-1 Layer 2, 2 Channels, 48 KHz, 20 bit, 384 Kbps (recommended)Thanks
Chip
Matthew Stoessner replied 18 years, 8 months ago 5 Members · 5 Replies -
Bob Flood
June 8, 2007 at 2:25 pmchip
we are in the same boat. so far have sent 2 spots to DG, and in both cases we had to send a D1 or Digibeta tape to a local post house who is qualified to upload.
if you contact them, they will give you help. we received a compete spec sheet for MPEG2, Audio, and Video both SD and HD.
compressor 2 does not make the right streams, ie they want program and it makes transport.
they actaully have specs and or presets for Squeeze, MainConcept (Mac or PC) and Cleaner 6. so i think those are preferred
Be advised that they have to certify you prior to your real upload. we had to compress 3 differnt spots or 30 sec clips (varying the content between the three clips) and get it approved before we were go!
hope this helps!
“I like video because its so fast!”
Bob Flood
Greer & Associates, Inc. -
Etionee F. diaz
November 14, 2007 at 2:27 pmI’m also trying to set up our workflow to integrate sending ads over to DG Fastchannel and it seems to me like they’re not familiar with Final Cut Pro studio settings, mostly Avid workflows. I asked them to send me some sort of documentation on how to set up the encoder/compressor and all they replied was that I needed to download the software to be able to do 4:2:2 chroma and 720 X 512, but failed to give me the name of the actual software…
If you manage to find an answer to the setup question, please let me know! Send your reply to “ediaz@forcemediagroup.com”…
Thanks in advance for any help provided,
E.http://www.etionee.com
Bilingual Graphic Design & Digital Media Production -
Matthew Stoessner
December 27, 2007 at 4:09 pmI am working on getting approved with DG FastChannel right now. The biggest problem is resizing to 720 X 512. I’ve never heard of this format. Their solution is to use Main Concept MPEG encoder and resize the video. My videos are being rejected because they are blurry… duh, they were resized. We are using Avid and Premier (with Matrox Axio) and both output 720 x 486, so this is not just a FCP problem. I have a hard time believing that I am the only one questioning this. They should adjust to what our editing software will output.
What is the best way to resize and avoid stretching? Is there a setting in the MPEG encoder I am missing?
What is the 720 X 512 format and why are they using it?
M
Matt Steeves
January 4, 2008 at 6:57 pmI have downloaded Episode from flip4mac.com. This is what DG has recommended. They will even send you a preset if you ask them…so far it seems like a great program, still waiting for test results though. I would contact Rafael at the Dallas office, he knows what he’s doing.
Apple Certified Final Cut Pro 6
Mac Pro 3.0 Quad
Kona LHe
Panasonic HPX-2000 -
Matthew Stoessner
January 7, 2008 at 8:46 pmI can’t use Episode… I’m on a PC. I have found that it is better to add black to the top of the video instead of resizing. This seems to keep any interlace problems under control. I had to use AE to do that, but now I’m having a hard time keeping the 4:2:2 color profile. Testing continues. Let me know if anyone out there finds the best “cross-platform” solution.
M
