Activity › Forums › Apple Final Cut Pro Legacy › FCP to Compressor tests — A MUST READ!!!
Posted by Bryan Arnold on February 21, 2006 at 7:48 pmWell, it could not be as huge as I think, if something is wrong here with our setup, but….
Check out the page I posted:
https://www.visiontracks.com/compressortests/
What is going on here???? Is this something we all know, and I missed it? Or, is something wrong with my computer? Whatever the case, I will be using export quicktime then to compressor from now on.
Let me know what you all think..
-Bryan
Bryan Arnold replied 20 years, 7 months ago 6 Members · 10 Replies -
Aaron Neitz
February 21, 2006 at 7:55 pmhuh. looks like that gamma problem that seems to pop up all the time – especially with people using blackmagic codecs. depends on his setup. i’d recommend doing your own test.
Bryan Arnold
February 21, 2006 at 8:15 pmUpdate link to explain the setup here. CharlieX2, I think you misunderstood me, these are my tests… Unless you were telling others to run their own tests, in that case, nevermind.
Also, that would be ineresting to see if others have the same problem, running thier own tests.
Aaron Neitz
February 21, 2006 at 8:33 pmwhat’s your setup? what flavor of media are you coming from? RT effects? what’s the setting in video processing?
I just tried this test with 10 bit uncompressed, and the resulting m2v was exactly the same. FCP 5.0.4.
Bryan Arnold
February 21, 2006 at 8:50 pmSystem… G5, All the current updates to the os and final cut pro studio.
Source: DVCPRO-50 30p capture via SDI from deck to KONA-2 to fcp (dvcpro-50 codec in fcp).
No effects placed on clip, DVCPRO-50 NTSC default setting from FCP and KONA setups.
Kevin Monahan
February 21, 2006 at 9:05 pmAre you viewing the High Quality version of the QT output? By default it will not export at high quality. You have to enable High Quality in the Window>Get Movie Properties dialog.
Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com -
Martin Phillips
February 21, 2006 at 10:41 pmI noticed this some time back. Does it on the DV codec too so I don’t think the Decklink / Kona cards make any difference.
Joachim Freitag
February 22, 2006 at 8:33 ami recognized the problem in earlier releases and posted in this forum a few weeks ago. i’m working with the aja io-box and tried all possible options. since there i always export via quicktime-export and then put it into the compressor.
joachim freitag
http://www.forward.sh -
John Calhoun
February 23, 2006 at 1:48 amI read on the cow i think, a while back about exporting a reference then importing into compressor. The reasoning was, if i remember correctly, because compressor was a pretty buggy then and also for convenience sake. That way fcp isn’t tied up while compressing.
pxlmvr -
Bryan Arnold
February 23, 2006 at 3:31 pmI think that is what I am going to do for now on…
I burned tests to a DVD and tried them on some different sets with different players, and every time the reference looked better then the direct one.
