Activity › Forums › Apple Final Cut Pro Legacy › FCP to Compressor question
  • FCP to Compressor question
    Posted by Adam Taylor on September 6, 2010 at 9:33 am
    After sticking with the Export Queue for years, I finally decided to try the various ways of sending to Compressor.
    My only gripe with Export Queue was having no way to save favourite settings, and having to re-enter the same data every time i open it up. So time to try the options in Compressor…
    The one thing i cant seem to figure out though, is there a way to send to Compressor only the video between the in/out points on a timeline? Use In/Out Points is a great option in the Export Queue, but it seems to be lacking in the methods for sending to Compressor.
    If its possible – can someone explain how?
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    Rob Grauert replied 16 years ago 2 Members · 4 Replies
  • Rob Grauert
    September 6, 2010 at 11:51 am
    “My only gripe with Export Queue was having no way to save favourite settings, and having to re-enter the same data every time i open it up. So time to try the options in Compressor…”
    I dunno what an Export Queue is, but to create you own custom setting, choose a setting in the Settings tab. Near the top of that pane, there are 3 buttons (if you’re in FCS2, I dunno about the new FCS). The third button duplicates the selected setting. From there you can modify/name it in the Inspector tab. Then click the save button at the button of the Inspector
    “The one thing i cant seem to figure out though, is there a way to send to Compressor only the video between the in/out points on a timeline?”
    I’m not sure what you’re doing because I’ve always been able to mark In and Out points in my timeline and send whatever I want to Compressor. You can also mark In and Out points in the Preview window in Compressor. Or, mark your In and Out of your timeline, export a reference movie, then bring the reference movie into Compressor.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Adam Taylor
    September 6, 2010 at 12:06 pm
    Export Queue is fcp’s built in batch exporter.
    I have everything setup as i need in Compressor – thats not the problem…i need to send different sections of the timeline to different folders, at different settings. I found that compressor ended up with the same in/out points regardless of how i had set them prior to sending from FCP.
    I’ll try again – maybe my fault!
    Adam Taylor
    Oldham, UK
  • Adam Taylor
    September 6, 2010 at 1:18 pm
    following on from your reply Rob, i’ve done some more tests and know what i did wrong.
    if anyones interested, sending to Compressor from fcp will use the in/out points…however, once in Compressor i made the mistake of dragging the various clips into one batch window, applying the different settings to the various clips and submitting. Thats causes Compressor to lose the in/out point info and instead it renders the entire clip instead of the bit you set with I/O points.
    So as long as you don’t move a clip from its own batch window, it should export correctly when you apply your settings.
    adam
    Adam Taylor
    Oldham, UK
  • Rob Grauert
    September 6, 2010 at 1:23 pm
    Look at that, learnin something new everyday 🙂
    Rob Grauert, Jr.
