Activity › Forums › Apple Final Cut Pro Legacy › FCP TO Compressor problem
Posted by Richard Rodriguez on October 26, 2009 at 7:10 pmHello,
Have a problem with FCP and Compressor. Used to be able to export directly to compressor then apply a compressor setting and compress. Now I am getting an error when submit video file for compression.
Any suggestions? Thank you in advance.
Richard Rodriguez
Digital EdgeRichard Rodriguez
Jerry Hofmann replied 16 years, 11 months ago 2 Members · 6 Replies -
Jerry Hofmann
October 26, 2009 at 10:53 pmWhat is the error message say?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Jerry Hofmann
October 27, 2009 at 2:41 pmWELL! That’s descriptive… NOT.
My guess is that you have a file that is corrupted in the sequence. Often it’s a render file… might try sending to compressor without any renders. It’s actually the cleanest way to do a compression anyway… just takes a bit longer.
Jerry
Richard Rodriguez
October 27, 2009 at 2:58 pmThis the log associated with the error. Does this help?
Submission Time: 10/27/09 9:14:47 AM
Owner: richardrodriguez
Time Elapsed: 0:00:00
Time Remaining: 0:00:00
Percent Complete: 100
Status: FailedRichard Rodriguez
Richard Rodriguez
October 27, 2009 at 3:20 pmTried to encode without renders and still came up with same error
Richard Rodriguez
Jerry Hofmann
October 27, 2009 at 6:15 pmTry exporting a self contained movie… do you get an error? If so you have a bad media in the area where it chokes.. like if it gets to 50% then you know that about 50% into the sequence, you have a bad media file. I can’t read logs very well, just never bothered to learn them… it’s all computer code to me.
Jerry
