Activity Forums Apple Final Cut Pro Legacy FCP to Compressor ghost in the machine?
  • FCP to Compressor ghost in the machine?
    Posted by Anthony Popolo on January 5, 2012 at 6:51 pm
    Hi…
    Using FCP 6, Compressor 3, Mac G5, PowerPC…
    I’ve been doing the same type of projects (90 min, 2 angle DVDs) for 5-6 years, I’ve recently starting seeing odd things happening during my export from FCP through Compressor. For example:
    – I’d export audio to ac3 and end up with a completely silent track (DVDSP inspector verifies at 192kbps)
    – Export of video is black. OR
    – I would export two video tracks, one with a Compressor applied watermark, but it confuses the two videos and uses the wrong video for the watermark.
    – After export is complete, FCP closes the project (with NO error popup) and a project replaces it in the browser with a name something like “FA387598-41F6-8561-8720-19”
    As a investigative process (and workaround) I’ve been able to export the audio from FCP as an AIFF, then converting within Compressor and it turns out okay (done it 3 times). I don’t have the luxury of time to do that with the videos, but based on the audio investigation, I’m assuming the issue is a FCP export, rather than a Compressor issue (?)
    Any ideas?? Thanks.
    I’m thinking of reinstalling FCP, but I’m afraid I don’t know the best way to do that efficiently.
    Anthony Popolo
    Sunnyside Entertainment
    Anthony Popolo replied 14 years, 8 months ago 1 Member · 3 Replies
  • Anthony Popolo
    January 5, 2012 at 7:30 pm
    Thanks Dave. The restart didn’t help. I’m embarrassed to admit, I’ve never repaired permissions or trashed preferences before, so I’m not exactly sure how to do it. Can you point me to a step by step guide? I do have Warrior and will do that. Thanks
    Anthony Popolo
  • Anthony Popolo
    January 5, 2012 at 8:04 pm
    Thanks for pointing me the right direction. (My Disk Warrior is in process for the permissions). Thanks.
    Anthony Popolo
  • Anthony Popolo
    January 18, 2012 at 5:25 pm
    Problem solved, finally. Just a final update:
    After repairing permissions (Disc Utility and Disc Warrior), trashing preferences, and even after uninstalling and reinstalling entire FCP Studio, problem persisted. Then, I started seeing file save errors within FCP (“i/o error”). Turns out my hard drive which housed the FCP project files was slowly failing over time (not enough to reveal major issues or be noticed by warrior). This was apparently randomly corrupting my FCP files, specifically things related to exporting through Compressor). Prior to replacing the HD, I copied a bunch of folders to another drive and during the process found a number of corrupted files.
    I have since replaced the hard drive and all my NEW projects appear to process perfectly fine. Of course, all my previous projects are now suspect since damage to them has apparently been done (I tried to reprocess a previous problem project, and it is in fact still bad).
    Anyway, thanks for your help!
    Anthony
    Anthony Popolo
