Activity Forums Apple Final Cut Pro Legacy FCP to compressor
  • FCP to compressor
    Posted by Michael Allen on July 27, 2009 at 8:39 pm
    I am exporting a ProRes 1920×1080 60i clip as a self contained movie. I then selected the 120 min. best quality preset in compressor to make my mpeg2 and ac3 file for SD DVD. The quality is pretty bad. I get jaged edges and horizontal lines in the mpeg2 file and all text is of poor quality. It looks some what like a field order issue, but I can’t find a problem with my workflow. I exported some short test files of the program and tried to change a few settings in compressor but cannot fix the issue. Is there a better way to do this? Are there settings in compressor that really make a difference with something like this? Should I downrez before exporting from FCP. If so, what is the best way? I will take any suggestions on how to make a better SD DVD mpeg2 file from HD ProRes export. I am sure I can’t be the only one encountering these problems.
    Mike
    John Fishback
    replied 17 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    August 2, 2009 at 7:25 pm
    As you are scaling the image, you might try turning on frame controls in Compressor’s Inspector and choosing Best in the scaling quality setting. Hopefully that will help. BTW, how are you monitoring?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
