Activity › Forums › Apple Final Cut Pro Legacy › FCP to AFter Effects workflow
  • FCP to AFter Effects workflow
    Posted by Ben North on March 11, 2011 at 9:48 pm
    Hi i am a super newbie and need help.
    Basically im a doing a short and want to edit in fcp but there are a couple of shots i want to add effects to in after effects. WHta is teh best way to do this?
    I have read into because what needs doing is so small i gather i can just export the shots needed? How do i do this without losing quality and then take it back without quality loss?
    Thank you for any help
    Ben
    Rafael Amador replied 15 years, 6 months ago 4 Members · 4 Replies
  • Deleted User
    March 11, 2011 at 10:24 pm
    If you also have Premiere Pro you can export a XML from FCP and then read that XML in Premiere Pro. From there you can send it to AE. Or you can just export a flattened quicktime file from FCP and import it directly into AE.
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Euphonix MC Transport • Final Cut Studio 3 • Premiere Pro CS5
  • Chris Tompkins
    March 11, 2011 at 10:28 pm
    Just put you clip in a sequence alone and export current settings making a ref file (no need for self-contained). Or put In and Out marker around the shot in the sequence to be exported.
    Import that into AE.
    Render out to the same codec of your sequence.
    Import rendered file into FCP.
    Chris Tompkins
    Video Atlanta LLC
  • Ben North
    March 11, 2011 at 11:53 pm
    Hi Thanks for teh response. What do you mean by a reference file? And how to i export using current settings?
    Ben
  • Rafael Amador
    March 12, 2011 at 3:29 am
    [Ben North] “Basically im a doing a short and want to edit in fcp but there are a couple of shots i want to add effects to in after effects. WHta is teh best way to do this? “
    This script will lets you send your FC time-line to AE:
    https://www.popcornisland.com/2009/03/final-cut-2-after-effects/
    rafael
    http://www.nagavideo.com
