Activity Forums Adobe After Effects FCP to After Effects and back?
  • FCP to After Effects and back?
    Posted by Sean Tatalovich on January 22, 2009 at 12:08 am
    I don’t know if I should post this here or in FCP thread.
    I used to use FCP and forgot a few things and I am sure somethings have changed as well. I am trying to figure out the best way to use after Effects with FCP 6.
    Can I just drag a clip from FCP into AE? Or do I export as a file and import that into AE?
    Once that is done how do I export back into FCP?
    Any other tips regarding AE and FCP is appreciated?
    Sean Tatalovich replied 17 years, 7 months ago 4 Members · 6 Replies
  • Grant Swanson
    January 22, 2009 at 12:34 am
    Hi Sean,
    If you’re going to be going back and forth between fcp and ae a lot, I would seriously invest in Pro Import AE by Automatic Duck. It’s a bit pricey but it allows you to export your FCP timeline to AE.
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.net
  • Greg Antisdel
    January 22, 2009 at 12:54 am
    You can pick it up from Digital Juice right now for $247.50 (half Price).
    https://www.digitaljuice.com/products/products.asp?pid=834
  • Sean Tatalovich
    January 22, 2009 at 1:52 am
    Thanks Grant. but how do I take my clip from FCP and import into AE. I know there is a way without exporting out as a QT.mov
    You used to (1999) be able to export the clip as some FCP file, import into AE render FX and it would be already rendered in FCP.
  • Sean Tatalovich
    January 22, 2009 at 2:10 am
    This will explain better. When I used it in FCP 1.0 you could make a reference file from FCP. Export out of AE as Apple codec and into FCP without re-rendering.
    https://www.kenstone.net/fcp_homepage/porting_between_fcp_ae.html
    5 paragraph
  • Curious Turtle
    January 22, 2009 at 7:07 am
    If I’m reading you correctly, then you just want to get a clip out of FCP into AE. If so, then either mark the range on the timeline or do a matchframe (hit F) to load the specific clip into the Viewer.
    Then go to File > Export > Quicktime Movie. Keep the current settings, and turn off “Make Movie Self-contained”. This will create a by-reference movie.
    Import that into After Effects and do your thang. Then render it out to exactly the same settings as your FCP sequence settings, including codec, frame size & frame rate. You can now place that clip on the Final Cut timeline without rerendering.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Sean Tatalovich
    January 22, 2009 at 7:07 pm
    Perfect that’s what I meant thanks!
