Activity Forums Apple Final Cut Pro Legacy FCP to AE6.5 pixel aspect ratio ‘keep it native’
  • FCP to AE6.5 pixel aspect ratio ‘keep it native’
    Posted by Drpete on March 23, 2006 at 10:13 am
    Dear FCP
    When I export my reference movie from FCP HDV1080i PAL timeline I get an image size of 1920×1080
    In Aftereffects Pro 6.5 I can make a composition 1920×1080 however when I import the movie it does not fit the frame it is too small. If I re-interpret the pixel aspect ratio to widescreen it is too big! There seems to be no correct pixel aspect ratio for this format. FCP should be Non-square 1.33:1
    I want to composite some effects and then render out to the same codec for insert back into my FCP timeline. Without horizontal stretching the image which can introduce artifacts.
    Do I need too upgrade again?
    Many thanks drPETE
    SKIPZONE FILMS
    Drpete replied 20 years, 6 months ago 4 Members · 6 Replies
  • Kai Whittaker
    March 23, 2006 at 3:14 pm
    The pixel aspect ratio of HD 1080i is square as far as I know..
    Try using that setting in “interpret footage”.
    Kai
  • Bret Williams
    March 23, 2006 at 9:15 pm
    A little math answers the question…
    1920/1080 = 1.77 (not 1.33)
    16/9= 1.77
    So the pixels are square. Set interpretation to square in AE and you’ll be dead on.
  • Drpete
    March 23, 2006 at 9:20 pm
    But…
    When I check my factory setting for HDV it gives me the following:-
    Frame size HD 1440×1080 (16:9)
    Pixel Aspect HD 1440×1080
    HDV is anamorphic by nature so the pixels can’t be square.
    Sorry I am still confused.
    SKIPZONE FILMS
  • Drpete
    March 23, 2006 at 9:31 pm
    Your Maths is correct. It is spot on!
    However I still can’t understand how a 1440×1080 timeline with square pixels
    stretches to a 1920×1080 frame with ‘square pixels’
    Many thanks for problem solved it is just the principle now!
    Regards drPETE
    SKIPZONE FILMS
  • Mactrix
    March 24, 2006 at 10:05 pm
    In your first post you asked about HD 1080i …
    Here the pixel format is square with a full image size of 1920 x 1080.
    HDV however is 1440 x 1080 using none-square pixels.
    It’s squeezed on a 4:3 frame. FCP handles HDV nativ
    with 1440 x 1080 and according pixel format. However
    QuickTime will display HDV .MOVs with square pixels
    and so After Effects … you might loose a bit of quality
    by resizing the footage in AE and back to FCP but I
    think this won’t be visible.
  • Drpete
    March 25, 2006 at 7:18 pm
    Great. Many thanks for help.
    SKIPZONE FILMS
