Activity › Forums › Adobe After Effects › FCP to AE script
FCP to AE script
Posted by Tom Gomez on July 16, 2011 at 2:48 pmMany of you probably know about this… but here’s an amazing script from popcorn island for those of us still on FCP who can’t afford Automatic Duck…
https://www.popcornisland.com/2009/03/final-cut-2-after-effects/comment-page-4/#comment-13382
-Tom
YOU can help save TimeSpace. Join the Chronos Protectorate!Tom Gomez replied 15 years ago 3 Members · 5 Replies -
Barend Onneweer
July 16, 2011 at 5:38 pmIt sort of works. But if it can’t find the source footage it doesn’t put any placeholders in the timeline.
If you have Adobe Premiere Pro, you can import FCP xml projects into Premiere and then import the Premiere project into After Effects. More flexible and more control.
Barend
Raamw3rk – digital storytelling and visual effects
Todd Kopriva
July 16, 2011 at 6:11 pmI agree with Barend.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Tom Gomez
July 16, 2011 at 7:55 pmIt’s working like a charm for me… But yes, the copy-paste from Premiere to AE is pretty awesome.
YOU can help save TimeSpace. Join the Chronos Protectorate!https://www.95ers.com
https://www.SpaceAceMedia.com -
Barend Onneweer
July 17, 2011 at 10:21 pmIt works when all the source material is in the place that the script expects it to be. But when I get an xml from an editor that organized his source material into a different folder structure than I have it – usually the script doesn’t find all the sources. Instead of creating placeholders, it leaves gaps.
Premiere will offline the clip allowing me to manually relink to the footage.
Another example: if the editor used quicktime proxies of Red footage. If I don’t have the proxies the script will produce an empty timeline, whereas Premiere will let me replace the clips for the R3D files.
But the script was definitely very useful to me before Premiere could import FCP xmls.
Tom Gomez
July 26, 2011 at 3:11 amI do love the script and will use it until I’m totally on Premiere… but it causes weirdness in some of your other comps. So use the script in a fresh AE project and then import the comps into your main projects…
