Activity › Forums › Adobe After Effects › fcp to ae cs 5 color differences
Posted by Kevin Reeves on October 22, 2010 at 7:13 pmHey all, so ive been pulling my hair out reading article after article about color spaces in after effects yet i still cannot manage to get the result i need. My ultimate goal is to be able to use after effects to help with the shows we do in either avid or final cut pro but i have yet to be able to bring in a clip from avid/final cut and have the color stay the same on our scope. This morning i took a 1920×1080 apple pro res 422 QT which i made in final cut, double checked it on the scope, brought it into after effects and set my working color space to be HDTV (REC709) and it seems that after effects is still manipulating the color, more specifically its clipping the blacks. Any ideas of what i am missing? I didnt do anything to this clip in after effects except import it and changed the project settings to be HDTV(rec709). Thanks for any tips.
kevin
Kevin Reeves
kevin@kappastudios.com
http://www.kappastudios.comWalter Soyka replied 15 years, 11 months ago 3 Members · 11 Replies -
Walter Soyka
October 22, 2010 at 7:20 pm[Kevin Reeves] “This morning i took a 1920×1080 apple pro res 422 QT which i made in final cut, double checked it on the scope, brought it into after effects and set my working color space to be HDTV (REC709) and it seems that after effects is still manipulating the color, more specifically its clipping the blacks. Any ideas of what i am missing? I didnt do anything to this clip in after effects except import it and changed the project settings to be HDTV(rec709). Thanks for any tips.”
How are you rendering video out of After Effects? How are you monitoring the shift?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Kevin Reeves
October 22, 2010 at 7:30 pmI am rendering using these (1920×1080 QT apple pro res 422, rec709 color space)
We have a kona 3 card hooked up to a blackmagic ultra scope
Ill bring the rendered QT from after effects and place it in final cut right next to the clip that the original color bars QT was made from (full circle) and ill frame step back and forth and watch the black levels change.
Kevin Reeves
http://www.kappastudios.com -
Kevin Reeves
October 22, 2010 at 7:55 pmI read that earlier and for some reason fcp will not let me change that setting, and actually there is no value for the gamma.
To clarify the colors arent being stretched or pulled on my scope, its just that the blacks are being clipped.
Kevin Reeves
Kevin Reeves
October 22, 2010 at 8:13 pmThat is correct I selected it in the browser, command-9 and tried to select gamma but will not give me an option or an area to add a value.
I closed after effects and restarted fcp and it still will not let me change it.
I am curious because when i am in after effects, i use the kona 3 card to go to an external monitor as well as our blackmagic scope and i am seeing the blacks (more specifically the super black) being clipped there, before i even export. Makes me wonder if it is still a fcp gamma issue
Kevin Reeves
Walter Soyka
October 22, 2010 at 8:25 pmI think that the gamma setting is only available for RGB formats (like the Animation codec) — and this doesn’t sound like a gamma issue to me. If it were, you should be seeing shifts across the entire tonal range.
ProRes is 10-bit, but After Effects defaults to 8-bit processing. If you switch your project to 16 or 32 bpc and re-render, do you still see the clipped blacks?
Walter Soyka
Kevin Reeves
October 22, 2010 at 8:34 pmYes i just tried that and it is still clipping the black. This is bizzare
Kevin Reeves
Kevin Reeves
October 22, 2010 at 8:43 pmNope no change at all, it has to be some color setting in after effects that i am missing.
Kevin Reeves
Chris Wright
October 23, 2010 at 12:44 amis output module set at are you using h709 or 709 235?
did you fix your interpretations for prores in AE with the funky text file edit?https://technicolorsoftware.hostzi.com/
Walter Soyka
October 24, 2010 at 7:30 pm[Kevin Reeves] “Ill bring the rendered QT from after effects and place it in final cut right next to the clip that the original color bars QT was made from (full circle) and ill frame step back and forth and watch the black levels change.”
So you’re round-tripping color bars — are you seeing shadows clipped, or just super-blacks? I have had no problems round-tripping a few ProRes clips with FCP and AE CS5, but they had already been legalized. I haven’t tried with super-black or super-white.
After Effects can see super-black when processing in float (32 bpc), but getting them back out to FCP is a challenge. Negative RGB values will be preserved by rendering to floating point TIFF or PSD sequences, but Quicktime Player doesn’t do 32-bit image sequences, and Compressor clips them.
Chris mentioned Rec. 709 16-235 — this might be your best bet for preserving super-black. You’d have to expand it back in FCP with a color correction filter.
CS5 has the proper interpretation rules for ProRes — it’s CS3 and CS4 that require manually editing the interpretation file.
Walter Soyka
Chris Wright
October 24, 2010 at 7:55 pmunfortunately, there’s still a load of problems in cs5, see adobe’s post
and yes, legal broadcast standards get rendered in 16-235, that’s why your gamma goes all over the place.https://blogs.adobe.com/toddkopriva/2010/05/prores-4444-and-prores-422-in.html
