Activity Forums Apple Final Cut Pro Legacy FCP Timecode errors
  • FCP Timecode errors
    Posted by Walken on June 15, 2007 at 3:10 pm
    Hello all,
    I am having a problem capturing from a Sony HDW-2000. It is coming into an AJA Kona LH card as SD. What seems to be happening is the timecode is slipping a little bit. On tapes that I have captured, the timecode in FCP displays an earlier timecode than the one on the tape (for example, FCP shows 03:57:30;00 while the same image on the tape itself is at 04:01:30;00).
    This has created a problem because when I capture, FCP keeps trying to capture after the end of the tape because it thinks it is at an earlier point than it really is. BTW, when I log the clips under Log and Capture the timecode displays fine. Any ideas how to fix this?
    Walken replied 19 years, 2 months ago 2 Members · 2 Replies
  • Jim Calahan
    June 16, 2007 at 6:09 pm
    What frame rate was the footage shot at and what is the deck set to. We had a client who shot at 29.97 and the rental deck was set to 23.98 and it caused all sorts of problems. It involved using a paper clip to get into the right menu on the deck.
    Jim Calahan
    KVIE, Sacramento
  • Walken
    June 19, 2007 at 4:40 pm
    I just checked the deck, it’s actually not capable of anything but 29.97. Any other ideas?
