Activity › Forums › Apple Final Cut Pro Legacy › FCP text tracking exhibits jerky movement
  • FCP text tracking exhibits jerky movement
    Posted by Daniel Rucci on January 15, 2008 at 9:41 pm
    Hey everyone,
    I have a piece of text on screen and am keyframing the tracking parameter from a value of 1 to 3 over about 4 seconds. This is a 1280×1080 project @ 30fps.
    When rendered, the text doesn’t move smoothly, the movement is jerky. You can tell the computer is trying to make it smooth but just not getting accurate enough with it.
    I tried turning subpixel on and off, both did the same thing. Any other ideas?
    Matt Lyon replied 15 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Paul Escandon
    January 15, 2008 at 9:59 pm
    Change the motion filtering quality to best.
    Sequence Settings > Video processing tab > motion filtering quality – BEST.
    Try re rendering it out and see if there’s an improvement.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Russell Lasson
    January 15, 2008 at 10:04 pm
    You might try changing the sequence field dominance to “NONE”.
    Generally, FCP text tools stink. I’d use motion instead if you care about how it looks. Consider Motion as a text plugin for FCP if that helps you open it.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Daniel Rucci
    January 15, 2008 at 10:11 pm
    Thanks for the idea, Unfortunately not.
    I tried every combination of motion filtering quality and subpixel use, to no avail.
    I should mention this is DVCProHD and listed as 1080i60 in sequence settings, even though the bin says its 30fps
  • Daniel Rucci
    January 15, 2008 at 10:14 pm
    Russell,
    The field dominance change actually made my text look better in the canvas. Quite a bit less pixelly and the curves on the text were smoother, however the movement is still jerky.
    I won’t like rebuilding these text movenents in motion but I think that may be my last best option. I basically have to recreate them there from scratch then which is a bummer.
  • Phil Holt
    March 25, 2009 at 7:31 pm
    Hi there everyone. I too am experiencing this exact problem. Seems like a fairly major flaw in the software tbh.
    i have around 50 titles that i need to animate and im getting this effect over all of em *end rant*
    just wondering if anyone has found any new work arounds to the problem?
    thanks in advance.
    phil.
  • Daniel Rucci
    March 25, 2009 at 7:59 pm
    Use motion, or cross your fingers for a fix in the next version of FCP studio!
  • Matt Lyon
    May 8, 2011 at 12:03 am
    Really old thread, but I stumbled on it because I was having the same issue today.
    Try enabling motion blur, and cranking it: I set mine to 1000% and 4 samples. Definitely helps, but at the expense of adding a ton of render time. YMMV, depending on the exact nature of your titles.
    Hope this helps,
    Matt Lyon
    Editor
    Toronto
