Activity › Forums › Apple Final Cut Pro Legacy › FCP text editor
  • FCP text editor
    Posted by David Cummins on January 10, 2010 at 1:45 am
    I’m using FCP 7.0 text editor. I want to scale up text (from smaller to larger) during a transition. I can apply key frames on the Scale control for one text effect. Unfortunately the key frames settings apply globally to all my other text events, even if I have them on different video tracks. It appears FCP doesn’t allow discreet key frames settings per track. I suspect I need to create each text treatment, export as a video clip and then drop into my time line? Or should I take the time to learn Motion?
    Alexander Kallas replied 16 years, 8 months ago 3 Members · 3 Replies
  • Andy Mees
    January 10, 2010 at 4:13 am
    Hey David
    What you’re describing is not at all consistent with the usual behaviour of FCP when keyframing motion properties where normal operation allows only for setting keyframes on a clip by clip basis … there’s actually no basic facility for changing keyframe properties on a track by track or global basis at all.
    I’m guessing you may have some project or preferences corruption that’s causing this inconsistency, so as a first step you might try trashing your FCP preferences (or restoring a previously saved set). A good and free tool for this is Preference Manager from Digital Rebellion.
    Best
    Andy
  • David Cummins
    January 10, 2010 at 5:40 am
    Thanks for the advice. I’ve never had much luck with the text editor so I found a workaround. I’m creating my text in Photoshop with a key and exporting as a tiff. This slow me down a tiny bit but at least I don’t have to render out text in FCP. I can now use key frames to Scale and Rotate each clip with no problem.
    I’m hoping some day Apple will offer a real-time capabilities for text and image controls. Maybe the next version.
  • Alexander Kallas
    January 10, 2010 at 10:17 pm
    You can do what you want in Motion
    Cheers
    Alexander
