Activity › Forums › Apple Final Cut Pro Legacy › FCP taking too long to open
Posted by Jenny Himmelrick on May 12, 2010 at 2:31 pmI’ve been editing some big projects lately and my final cut is taking at least 15-20 minutes to open up anymore. What can I do to help it out so that I wont crash my system? I’m going to be uploading some Apple ProRes footage soon and I just know that those files are going to make it take even longer to open the program. I read somewhere about deleting rendered files or changing something about RT? I dont really understand all that stuff…help, please!
Jenny
John Fishbackreplied 13 years, 8 months ago 5 Members · 8 Replies
Tom Bucknall
May 12, 2010 at 3:26 pmAre you opening a project when you open FCP, and if so what size is the project you are loading. Typically FCP will not work well with projects >100MB.
Tom
John Fishback
May 12, 2010 at 3:43 pmNever hurts to trash prefs and repair permissions.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jared Levy
September 28, 2010 at 4:16 pmA project I am currently working on, a documentary with roughly 1.5 terabytes of material (Canon 5D Mark II files are exploding this project) is currently 130 MBs… I read in the previous post that projects over 100 MBs slow FCP down a lot. Right now, it is taking an excruciating 45-60 minutes to open the project in FCP. Even when open, it is prone to random shut downs and is constantly lagging.
Any suggestions about ways to minimize the project? I have a lot of timelapses with thousands of photos. I am sure that is hurting performance but I am not sure how to rectify the issue. Should I delete all render files for the timelapses and only render them at the last moment? Does that even help the project size?
I have 8gbs of ram and according to my activity monitor, lack of ram is not the issue.
Thanks so much!
Jared Levy
September 28, 2010 at 5:34 pmJust want to update. I created a new project and dumped all of the timelapse material there. That drastically dropped the project weight for the A-camera stuff. As for the timelapse project, it is still very heavy but I plan on exporting out movie versions of each timelapse sequence, thereby reducing the images from thousands to simply one movie file per timelapse. I am hoping I can then import those finished movie files back into the main project.
If anyone has ideas to further help this out… I’m all ears, but so far so good.
Lanny Cotler
January 13, 2013 at 5:25 amI also am finding FCPX to open painfully slowly. I must say that currently all my projects are with still images, not video clips. This it seems is important for FCPX.
I speeded things up (from 20 mins to 10 mins) by removing all still images greater than 2K pixels wide.
And I have a permanent catalog of images I need ONLINE of more than 3700 images!
I’m also experiencing TOTAL COMPUTER (MacBookPro8,3 – 16 GB RAM) LOCKUP that not even Force Quit will remedy. I have to bomb the machine with Power Button crash. Very disconcerting. This happens usually during rendering. Four times in a row the machine froze on 39% in the render window. What gives?!
While there are many features that I love in FCPX, perhaps I should find another editing software for my work with stills.
LannyATlcotler.com
John Fishback
January 13, 2013 at 4:28 pmI’ve recently had slow down & lockup issues. I found that running Disk Warrior & then Repair Permissions helped considerably. Disk health is apparently very important with FCPX. Also, I use Event Manager X which only opens the event you’re working on.
John
MacPro 8-core 2.8GHz, 8 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.6Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Lanny Cotler
January 13, 2013 at 7:27 pmI use Event Manager X, too. It’s good.
I’ve repaired permissions, but don’t have Disk Warrior. Should I get it?
Lanny
John Fishback
January 13, 2013 at 8:19 pmDisk Warrior is a lifesaver. If there’s one program every Mac owner should have, Disk Warrior’s it.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
