Activity › Forums › Apple Final Cut Pro Legacy › FCP sync and signal issues
  • FCP sync and signal issues
    Posted by Kyle Davidson on August 17, 2005 at 10:41 pm
    Hi all,
    I am having a problem with audio sync and another problem with the video signal to monitor preview. To understand my problem let me first explain how my system is set up:
    I have my box running to the AJA Io La, and that running to the monitor, and a raid hard disk. Mine is one of three networked boxes.
    The problem is that when I play a clip in the timeline under the preferences when I change the audio playback from AJA Io out to built in audio, the audio looses sync and is almost like it gets progressively worse the longer it plays. It plays fine if I leave playback on AJA out but then open my log and capture box and play what is in the timeline.
    My second problem is that when my video is previewing on the monitor there are heavy glitches, almost like a lose of video signal. The funny thing is that when I open the project off the raid from another computer, it plays just fine. I have run through the settings and am at a loss. Maybe it is something in the box. Hopefully one of you fine community members can point me on the right path to fix this.
    “I’ve got one! I have a special purpose. I was afraid to tell you about it!”
    Chris Tompkins replied 21 years, 1 month ago 2 Members · 1 Reply
  • Chris Tompkins
    August 18, 2005 at 1:03 pm
    Your audio should play out the AJA IO LA. Your video and audio play out throught the firewire cable from the mac to the IO From the IO LA to your monitor, deck, mixer
