Activity Forums Avid Media Composer FCP Switcher – How do you turn off an effect?
  • FCP Switcher – How do you turn off an effect?
    Posted by Gustavo Bermudas on March 18, 2012 at 8:39 am
    I apologize in advance, I’m just switching from FCP and it’s been a bit harder than I thought. I couldn’t find any info on how to disable / enable and effect, at least neither in the manual nor on google.
    I know Boris has a bypass button, but for example, I need to bypass a color correction effect and I cannot find a way to do it.
    Anna Dolnyk replied 10 years, 9 months ago 3 Members · 3 Replies
  • Scott Cole
    March 18, 2012 at 12:12 pm
    There is no simple way to “bypass” an entire effect in most Avid supplied effects (excepting the supplied Boris effects). You can remove them; look for the little circle/slash icon. I would recommend you save your effect by dragging the effect icon from the top left corner of the effect parameter window to your bin, and labeling it if need be, prior to removing the effect. Ctrl-Z and Ctrl-R to toggle back and forth between the effect in and out.
    M. Scott Cole
    Senior Post Production Editor
    60 MINUTES
    CBS News, NYC
    sc6@cbsnews.com
    mscottc@comcast.net
  • Gustavo Bermudas
    March 19, 2012 at 4:13 am
    Thanks a lot Scott!
  • Anna Dolnyk
    December 4, 2015 at 2:29 pm
    Actually, there is an opportunity to bypass the effect. In Effect Editor there is a Dual Split button (right side of Effect Editor). It splits the Effect Preview monitor in half to show the image with and without effects applied to it. If you want to see the whole image without any effects applied you can adjust the Dual Split Image Display by dragging one of the box’s triangular handles in the monitor.
    Anna Dolnyk, QA Engineer
