Activity › Forums › Apple Final Cut Pro Legacy › fcp studio dropping frames and freezing up
Posted by Jenny Roethlisberger on June 22, 2009 at 8:43 pmcan someone tell my why my fcp studio keeps dropping frames then freezing up when i am editing HD footage? it works fine for awhile when i begin, then after awhile it starts this. i had this problem before and reformatted my external hd and that seemed to work for awhile but its doing it again.
Help??Jenny Roethlisberger replied 17 years, 3 months ago 4 Members · 9 Replies -
Jaap Verdenius
June 22, 2009 at 9:00 pmAnyone reading this could think of a multitude of reason so it might be handy if you give some more info on your project, your sequence, the media and last but not least your hardware…
Jaap
Jeremy Garchow
June 22, 2009 at 9:01 pmWhat format of HD? sounds like your drive isn’t fast enough or close to full.
Stephen Vidano
June 22, 2009 at 9:39 pmHow large is your project file? Not with the media. Just the FCP project file.
I’ve had situations where I’ve had a 300mb project file and was it running from my external hard drive. Once I moved the actual project file to my desktop and opened the project from there it ran better.
But, JAAP is right. This could be a number of issues.
How many layers of video?
What’s your resolution?
Is your video native to a video setting? Or not?
RAM?
Stephen Vidano
TuneSociety.com
“Set Your Music Free” -
June 22, 2009 at 10:17 pmi have a mac mini, 2G RAM, 2G intel core 2 duo
iomega minimax external hd, 750G- drive has 420G taken up
connected via firewire 400sequence set at HD 1440×1080, media same
3 layers of video
128G of mediathat enough info?
Stephen Vidano
June 23, 2009 at 12:44 amYeah.
The “red lights” that come up are:
Mac Mini
2gb RAM
2G
HD sequence with 3 layers.Sooo…not sure the Mini (with 2gb RAM) can really handle that.
You might want to try your project on a friend’s 8 core…just to see if there is a difference?
Stephen Vidano
TuneSociety.com
Jaap Verdenius
June 23, 2009 at 5:53 amAlso, FW400 is slow. What is the data rate of your media (look it up in the browser)?
Jaap
Jeremy Garchow
June 23, 2009 at 1:17 pmYes, that’s enough info, but that is computer is not enough computer to edit anything reliably, let alone HD.
I’d suggest a more capable computer. A 17″ MacBook Pro at the very least, if not a desktop.
Jeremy
June 25, 2009 at 5:26 pmmy set up seemed to work fine for awhile though, thats why i was wondering if maybe it was my hard drive or the connection speed…
