Activity Forums Apple Final Cut Pro Legacy FCP Studio 2 upgrade problems
  • FCP Studio 2 upgrade problems
    Posted by Kenfile on July 10, 2007 at 8:13 pm
    Hello,
    I noticed someone had a similar problem posted yesterday but the response did not seem to help.
    I have just installed FCP Studio 2 and I am unable to update a previous project. When I do, the project does not recognize the media files. The audio will play but the video will not. The original project was digitized at DV/DVCPRO – NTSC (for offline purposes). I don’t see an easy setup in this vers. that is similar… is that the problem?
    Also, when I edit in the timeline, FCP sometimes just dumps out.
    I have tried creating a new project and importing the previously digitized files just to see if that would work and it doesn’t.
    Any thoughts?
    Ken Filewych
    OSX 10.4.9
    Dual 2.3 GHz PowerPC G5
    1.5 GB DDR SDRAM
    QT 7.1.6
    Kenfile replied 19 years, 2 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    July 10, 2007 at 10:16 pm
    How did you perform the upgrade? Did you start with a new startup disk or just run the “upgrade” over a previous version or?
    Jerry
  • Kenfile
    July 10, 2007 at 11:00 pm
    Hello Jerry,
    I have purchased a FC Studio 2 upgrade pack so I used those disks to install (upgrade) the FC Studio 1 existing on the computer. I did get an installation successful at the end of the install.
    Ken Filewych
  • Jerry Hofmann
    July 11, 2007 at 2:43 pm
    My guts tell me that you need to do a cleaner install… i.e. erase and install OS X, then run software update to get to the latest software, then install Studio 2 by itself. You’ll only need the serial numbers from your earlier version, and the new version… no need to install FCS 1 first.
    Jerry
  • Kenfile
    July 11, 2007 at 4:48 pm
    Hello Jerry,
    Your gut was basically right. I tried to wipe all FCP off and re-install Studio and then Studio 2 but that didn’t work. I cleaned up again, and then installed….. wait for it…. FCP 3 !!! … and then repeated the upgrade path. I restarted and check each version along the way and that seemed to do it. So I at least saved myself a OS install.
    Thanks for your help…
    Ken
