Activity Forums Apple Final Cut Pro Legacy FCP Strange Render Issues
  • FCP Strange Render Issues
    Posted by Robin Kress on May 2, 2010 at 3:02 pm
    i am running Final Cut Pro 7 on a Mac Pro with 10.6.3.
    For the first time since upgrading to FCP 7 i have encountered a very strange thing.
    Here’s the scenario:
    I have a 2 min XDCAM 720p25 Sequence with a few layers of audio and a roughly 3 of video. I have proceeded rendering the the entire sequence.
    Now here’s the strange part, once the render has completed and i proceed to export the sequence, using the same settings and the export has completed, the entire sequence suddenly has an orange Unlimited Render strip above it. Even after closing without saving and opening the project again the render strip is still visible.
    i have deleted all preference files, the necessary ones in the Final Cut Pro User Data folder and the FCP plist.
    if anyone can help please contact me urgently!
    Andy Mees replied 16 years, 4 months ago 2 Members · 1 Reply
  • Andy Mees
    May 2, 2010 at 3:44 pm
    That’s an odd one. Does it appear to be a UI glitch or do you actually seem to get less than full quality playback?
    Do you have the Video Scopes window displayed? If so, do you have Video Scopes Playback enabled under the RT menu? If so, try disabling it (or close the scopes window).
    Best
    Andy
