Activity Forums Blackmagic Design fcp still crashing
  • fcp still crashing
    Posted by Patrick Kofler on March 19, 2007 at 12:41 pm
    Hi guys,
    with any bmd easy setting in fcp the hole system sooner or later crashes completely. This does not happen in dv easy setting for instance. What I tried so far: tried different ram configurations (originally we had 6 gb installed, because we have a lot of rendering to do with this machine; I tried 2, 3 and 4gb, and yes, placed in pairs); changed the pci e slots and the exapnsion slot configurations. The result is always the same. When I place the cursor at the beginning of the timeline (either with the key or the mouse) the system freezes, not always, but often. It happens also (but not so often) when when I place the cursor anywhere in the timeline.
    Should I try older drivers (5.7)? If yes, where do I find them?
    Or do I simply have to wait for the next driver update? It would be good to know that, at least.
    Thanks for any suggestions!
    Patrick
    2×3 GHz Mac Pro
    6 (2,3,4) GB ram
    xserve raid (fibre channel card; which slot is best, btw?)
    bmd decklink sp pci e
    Mike Procunier replied 19 years, 5 months ago 6 Members · 10 Replies
  • 10 Replies
  • Jose Guzman
    March 20, 2007 at 1:38 am
    Hey Patrick,
    Trying to troubleshoot an incident at a facility that I’m working at where too. We’re using the Decklink, and I the system is crashing when we scrub the timeline. Took the RAID array offline to issolate the problem, and it was still crashing.
    I’m curious, had you recently updated the OS to 10.4.9? I think we did, and I just want to see if I can rule that out.
    Jose
  • Patrick Kofler
    March 20, 2007 at 7:51 am
    hi jose,
    no, we didn’t update to 10.4.9. Now I’m waiting with any update …
    saludos patrick
  • Kristian Lam
    March 21, 2007 at 12:40 am
    Hi Patrick,
    There’s a bug right now and where more than 2GB of RAM will crash your Mac Pro when using the DeckLink Extreme PCIe or SP PCIe. We’re working on it right now. As a temporary workaround, you’ll need to limit the amount of RAM in your Mac Pro to 2 GB.
    regards
    Kristian Lam
    Blackmagic Design
  • Dan Sparks
    March 21, 2007 at 5:54 pm
    Is this true for the HD Extreme card as well? I currently have 2GB RAM in my Mac Pro, but was considering going to 4GB.
    Dan Sparks
    Tricom Video
  • Kristian Lam
    March 21, 2007 at 11:12 pm
    Hi Dan,
    The HD Extreme is fine. This issue only affects the DeckLink SP PCIe and the DeckLink Extreme PCIe.
    regards
    Kristian Lam
    Blackmagic Design
  • Rob Moreno
    March 22, 2007 at 5:15 am
    Are there any known issues with Decklink HD Studio? I’m consistently experiencing crashes when switching between DV NTSC and Blackmagic 8-bit uncompressed in the capture input setting. Mac Pro, 5 GB of RAM.
    Rob
  • Kristian Lam
    March 22, 2007 at 5:38 am
    If you’re experiencing crashes, please send us the copy of the crash log and your system profile. The email address is support[at]blackmagic-design.com
    If it’s a kernel panic, send use the kernel panic log which is called “panic.log” and is located in “/Library/Log”.
    regards
    Kristian Lam
    Blackmagic Design
  • Mike Procunier
    March 30, 2007 at 7:59 pm
    Do you think the bug will ever get fixed, or should I convince my boss to pony up for an Extreme HD? Since I “moved up” to a MacPro in November I’ve been patiently waiting for the forthcoming software update that’ll fix this. The only solution I’ve found is to physically remove 2GB of RAM (originally 4GB). I tried reducing the FCP Memory Usage in System Settings but still get crashes. Is there a way to reduce the Decklink’s Memory usage perhaps?
  • Kristian Lam
    March 31, 2007 at 5:43 am
    Hi Mike,
    Yes, this bug will get fixed. We’re working on it right now and it’s in the priority list. I’ve also embargoed the engineer’s Tim Tam supplies until this gets addressed.
    regards
    Kristian Lam
    Blackmagic Design
  • Mike Procunier
    April 2, 2007 at 1:16 pm
    Thanks Kristian. It’s reassuring that you know what makes an engineer tick. (Tim Tams)
