Activity › Forums › Apple Final Cut Pro Legacy › FCP startup slow
  • Matt Callac
    July 24, 2007 at 10:08 pm
    Have you tried trashing prefs? Also are you opening a project directly or are you just opening final cut? If you are opening the project directly how big is that file. Usually more/longer sequences you have in FCP the larger the file size. Sometimes when i file size gets really big it just takes time for FCP to get all it’s ducks in a row.
    -mattyc
    Raising money for Blood:Water Mission to help build wells in Africa. I’m
    putting my hair on the line to raise some money.
    Check it out https://rattail.callac.com
  • Frank J. lozano
    July 24, 2007 at 11:27 pm
    Thanks. What if you close all projects before closing FCP? Maybe then it will boot up faster?
  • Rafael Amador
    July 25, 2007 at 1:17 am
    Hi Frank,
    How do you keep your system? Do you run Diskwarrior or Techtools? Before to look for posible problems in FC, make sure that your system is optimiced.
    Cheers,
    Rafael
  • John Burgan
    July 25, 2007 at 12:36 pm
    Check the size of your project file, especially if you’re working on a large or complex piece. It can help if you slim it down by splitting the project up and adopting a different workflow.
    Break the project down first into Media/Edits, then further down into chapters/acts/interviews, whatever seems most logical. Also weed out redundant edits by archiving them, keeping the project with your main edit up to date and as lean as possible.
    There’s no problem for FCP to have multiple projects open simultaneously, you can copy, cut and paste between them.
