  • Posted by Gracias on June 13, 2005 at 4:54 am
    Hello,
    I did a speed change on FCP 4.5 on G5 ‘ving Cinewave card, it was not good as I did not get the result what I wanted,as I saw few jerk while playback.
    The same I tried with Blackmagic Card, I found the output quite satisfactory with speed change.
    Is there any issues with Cinewave card. Will it get resolved with FCP 5
    Waiting for ur imeediate reply.
    Thanx
    Kshitija
    Michael Horton replied 21 years, 2 months ago 3 Members · 6 Replies
  • Michael Horton
    June 13, 2005 at 5:00 am
    Well t wont be resolved with 5.0 that is for sure. Cinewave dropped support for FCP. I suspect its an FCP issue rather than a Cinewave one. Is the clip you are applying the speed change too captured using Capture Now and over 15 minutes?
    Michael Horton
    lafcpug
    https://www.lafcpug.org
  • Gunner Jones
    June 13, 2005 at 6:29 pm
    How does it look in your video monitor? Check that for sure.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Gracias
    June 14, 2005 at 1:14 am
    Hello,
    Thx Michael, Well I did batch capture n the duration of the each clip is not exceeding 10mts either.
    I did evrything like formatting, My OS is also 10.3.5
    If I change the RAM will it resolve the issue. Because I have identical FCP machine it is not coming over there.
    Regards
    Najib
  • Michael Horton
    June 14, 2005 at 1:23 am
    So are you looking at this on an external monitor and did you render at high quality safe mode? Also make sure canvas window is set to fit to window
    Michael Horton
    lafcpug
  • Gracias
    June 14, 2005 at 5:02 am
    Hello,
    Yeah I am looking onthe ext monitor and the jitter is making it visible clearly.
    If I have to change the ram which one I should go for.
    Thanx
    Najeeb
  • Michael Horton
    June 14, 2005 at 5:17 am
    Its not your ram. Your machine works right? Then its not your Ram. You need to give us a lot more info before we can help
    Michael Horton
    lafcpug
